User interface:
By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
Most LED headlight replacements don’t (can’t, in fact) have the chips exactly placed where the filaments would be in a regular bulb. That throws off the focus, and you lose the sharp cutoff at the top of the beam. So there’s much more glare to oncoming drivers.
Even with “lowbeams” on, to oncoming drivers, the lights will look overly bright as if driving with “highbeams”. Easy way to get pulled over and cited. But just in general, it’s not very nice.
I have all LED bulbs in my exterior lighting except the headlights. I bought several different types of “bulbs” for front/rear turn-signals, marker lights, etc., and am using those which have a good appearance and brightness, essentially “cherrypicking” the good ones.
Headlights, though, nope nope nope. They might be bright as far as lighting up all of Hell’s Creation in front of you, but they’d also blind oncoming drivers. And I don’t want to risk getting a ticket, or worse, having my car impounded for “dangerous” equipment. ($$:money_mouth_face:
Temperature control protection: When the temperature of the flashlight exceeds 50 degrees, it will automatically downshift, and the brightness can be manually adjusted after downshifting.
When using 18650 Li-ion batteries, an 18650 conversion tube is required (not including 18650 battery and conversion tube).
Supports one pointed 21700 lithium battery with protective plate.
Waterproof: IPX8 (submersible to 2m for 30 minutes).
Details:
Waterproof: IPX8 (submersible to 2m)
Impact resistance: 1m
Head diameter: 22mm
Tube diameter: 19/20mm
Please note:
The intensity of the flashlight is extremely high, and it is strictly forbidden to shine directly into the eyes.
Keep away from children.
ArtieT59, the price of fenix Ld22 v2 is $56.93. We will have a site-wide anniversary celebration on June 15th. You can get the discount at that time. Thank you.
Paul321, XOSS G+ has the rubber gasket, bile computer mount, rubber band, USB cable with it. We will add the details to the Specifications and upload a picture.
Adopt SMD2835 high-efficiency chips, high brightness, low power consumption, low light decay, no flicker, soft light, energy-saving, and environmental, more than 85% energy saving than traditional halogen lamps.
Built-in gravity sensor, first turn on the light by touching the switch, tilt to the side with the touch switch, and the light turns on. tilt to the other side without the touch switch, the light turns off, and repeated operations will keep turning the light on/off repeatedly.
The unique appearance design and the seesaw-shaped lamp body design make gravity sensing operation more simple and convenient.
Multiple power supply methods. Built-in 400mAh battery, when the battery runs out, you can plug the USB cable into various USB device interfaces such as computer, power bank, USB adapter, etc. for charging, which is very convenient and practical (We give away 1 meter USB cable).
There is a touch switch on the lamp, long press can stepless dimming, and adjust the desired brightness according to actual needs.
Using ABS shell material, efficient heat dissipation, improves heat dissipation efficiency, effectively prolongs service life up to 50000 hours, and can work for a long time.
No installation is required, just place the light where you need it and use it. It is very convenient to use.
Applications:
This LED light can be used for a study desk, bedside, computer desk, living room, bedroom, kitchen, cabinet, bathroom, etc.
