If there is enough interest will 519a 2700k be available in the future?
I think Hank has ordered 2700k, they just haven’t arrived yet.
How much output should one expect from 4x 519a paired with the boost driver?
Around 1,800?
I saw an email from Hank stating 2700k would be in next week.
My guess or estimation… at least 2400….
Around 1,800?
For those wondering about outputs from quad lights. Check out this guide from Reddit. Reddit - Dive into anything
Basically, to calculate output, take the output of 4 LEDs at 2A, remove 5-10% from heat, and 10-20% from optics, and you’ve got the final output.
1920 lumens
So meaning base on raw data from Djozz, 519A @2A for 651 lumens… How much we will be getting?
For those wondering about outputs from quad lights. Check out this guide from Reddit. https://www.reddit.com/r/flashlight/comments/uewiqz/more_estimates_of_outputs_of_various_emitters_for/
Why are the results of this table for the xpl hi version lower than in reality?
In theory, things are the same in theory and in practice…
The author relies on the test results, but for the xpl hi version he intentionally lowers these values. This table sucks
So yeah, 2000 lumens from the 519A model at 12V 2A seems perfectly reasonable.
All the estimates are lowered by the same to account for optical efficiency (85%), and XP-L HI are lowered to get to maukka lumens from Texas Ace lumens using a 0.925 factor like in this output comparison: https://budgetlightforum.com/t/-/64360/55
The 80cri XP-L HI is adjusted using the ratio of flux bins to estimate the lower output of high cri vs the low cri test data
btw I'm the author, I'm happy to hear any suggestions for more accurate estimates
trevormbell:For those wondering about outputs from quad lights. Check out this guide from Reddit. https://www.reddit.com/r/flashlight/comments/uewiqz/more_estimates_of_outputs_of_various_emitters_for/
Because Texas Ace’s lumens are higher than reality (= Maukka lumens, he’s the only one here with a calibrated professional integrating sphere)
Interestingly enough, there’s a very very recent LED tests in which TA’s numbers are very close to reality lmao.
BOMBAY: trevormbell:For those wondering about outputs from quad lights. Check out this guide from Reddit. https://www.reddit.com/r/flashlight/comments/uewiqz/more_estimates_of_outputs_of_various_emitters_for/
And are these tables inaccurate or correct? -
http://pct.cree.com/dt/index.html
[/quote]
XP-L HI V2 at 2A with Tj = 80C (have to guess here) : 689lm
TA result with TA to maukka factor : 685lm
Pretty close.
BOMBAY:And are these tables inaccurate or correct? -
Pretty close.
[/quote]
Well, you can control this environment and create conditions in which 219b will be brighter than xpl hi, regards
And where can I find information about the temperature at which other types of LEDs were tested?
Does anyone know what is the correct Anduril 2 build for the boost driver?
