ArtieT59, the price of fenix Ld22 v2 is $56.93. We will have a site-wide anniversary celebration on June 15th. You can get the discount at that time. Thank you.
Paul321, XOSS G+ has the rubber gasket, bile computer mount, rubber band, USB cable with it. We will add the details to the Specifications and upload a picture.
Adopt SMD2835 high-efficiency chips, high brightness, low power consumption, low light decay, no flicker, soft light, energy-saving, and environmental, more than 85% energy saving than traditional halogen lamps.
Built-in gravity sensor, first turn on the light by touching the switch, tilt to the side with the touch switch, and the light turns on. tilt to the other side without the touch switch, the light turns off, and repeated operations will keep turning the light on/off repeatedly.
The unique appearance design and the seesaw-shaped lamp body design make gravity sensing operation more simple and convenient.
Multiple power supply methods. Built-in 400mAh battery, when the battery runs out, you can plug the USB cable into various USB device interfaces such as computer, power bank, USB adapter, etc. for charging, which is very convenient and practical (We give away 1 meter USB cable).
There is a touch switch on the lamp, long press can stepless dimming, and adjust the desired brightness according to actual needs.
Using ABS shell material, efficient heat dissipation, improves heat dissipation efficiency, effectively prolongs service life up to 50000 hours, and can work for a long time.
No installation is required, just place the light where you need it and use it. It is very convenient to use.
Applications:
This LED light can be used for a study desk, bedside, computer desk, living room, bedroom, kitchen, cabinet, bathroom, etc.
Good News! On the occasion of this anniversary sale, FastTech has prepared many activities with big discounts for our customers. It will be the greatest sale event of the year and definitely maximize your savings! SHOP MORE, SAVE MORE! Don’t forget to set alarms ahead of time, so you won’t miss anything!
The Gift Certificate is good as cash, a fast and easy way to check out, you can use it to get anything you like.
In addition, gift certificates can be used in conjunction with other site wide coupon promotions. And the gift certificates are valid for 5 years from the purchase date.
The Fenix TK22 TAC military flashlight stands out in performance and tactical deployment. Designed with the tactical and on-duty lighting needs in mind, the TK22 TAC features Tactical mode and Duty mode. Included with a 21700 rechargeable Li-ion battery, the TK22 TAC is an up to 2800 lumens flashlight in turbo output while throwing its beam a distance up to 540 meters. In Duty Mode, the TK22 TAC delivers 5 output modes including a strobe. Switch to the Tactical Mode to operate for fast, simplified selection of turbo and instant strobe. Perfect for professional use, security and law enforcement, you can count on the TK22 TAC to deliver reliable, powerful lighting for a variety of situations.
2800 lumens maximum output; 540 meters maximum beam distance.
One Luminus SFT70 LED with a lifespan of 50,000 hours.
Included a 21700 rechargeable Li-ion battery with USB Type C port.
Mechanical operation with rapid react dual mode.
Tactical and Duty modes for flexibly needed choice and operation.
Patented dual-function tactical switch for instantly tactical activation.
Single-handed toggle switch for mode selection.
Lockout function avoids accidental activation.
Innovative APF technology system make super tactical flashlight.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
1m impact resistance.
Fitted with high-performance industrial components, the light could operate (certain function fails due to different batteries) normally in temperature from –35 to 45’C.
The Fenix BC21R V3.0 is a professional bicycle light for mountain and road cycling, suitable for high-intensity and long-distance cycling users. The bicycle light emits an impressive output of 1200 lumens and can be seen at an impressive 142 meters. The light is USB Type-C rechargeable and gets powered by the included 18650/2600mAh battery. It can be used with a bicycle helmet holder and can be installed on a GoPro standard interface for safer riding. Innovatively designed quick-release mount and full-metal housing for better dissipation allow this versatile light to illuminate your trails confidently.
1200 lumens maximum output and 142 meters maximum beam distance.
A Luminus SST40 LED with a lifespan of 50,000 hours.
Included a 2600mAh/18650 Li-ion battery.
USB Type C charging.
Quick-release design, two-step assembly and disassembly.
Easy and fast operation with a single switch.
Boot-up battery level indication and low-voltage warning.
