【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
8 days to arrive, pretty quick! Color temp is definitely on the cooler side, but the tint seems fine, imo. Would love to see a lower CCT version in the future :+1:
Got mine, actually love the tint! But, for the life of me I cannot set an autolock timer. In advanced, locked out and 10H does nothing. What am I doing wrong? Also, any firmware updates for the aux leds on when main light is on? Did not see a hex file on TK’s site.
Already available for preorder on Aliexpress in 4000K with black or red body and one new aux color (green). Looks like you can order but they won’t be ready until the 20th. I haven’t even seen mine yet (it’s in my mailbox) but I still may order a red one in 4000K.
I found this on the threads in the head of my light, like the drill bit was tilted… in 2 places. Screws on ok, but still… Still can’t get auto lock enabled. Does the stock firmware even have it?
Finally got autolock on… button must be pressed very squarely to take accurate counts. I really love it and am thrilled by the first 6000k that I like!
That is normal. The PCB has a small tab for alignment and the cutout is required to put it in. Many Sofirn/Wurkkos flashlights have it.
Not officially, Toykeeper probably wasn’t even involved in the development of the TS10. I have made my own hex that fixes this issue and can share it if anyone wants it. It is basically just sofirn-sp36-t1616 with a single line of the code commented out.
Is any other problem happen when line of the code commented out?
we now use the same firmware as sp10 pro
The SP10 Pro firmware has special code for the 1.5 V support and the boost regulator. Not sure if that is a good idea.
LEDs while the flashlight is on can be disabled by adding this line to the configuration:
#undef USE_INDICATOR_LED_WHILE_RAMPING
OPS, sorry, the firmware is sp36 pro
I was too slow on the first batch
The big thing that feels different to me is the lack of blue and glare. The cri does not hurt either. At high drive the Duv actually goes ever so slightly negative as well!
It really is nice!
Can those of you who have the light post some pictures? Specifically:
  • What does the button look like?
  • Beam and beam pattern?
  • Side-by-side with an FWAA - based on the picture someone posted with an SP10Pro I think this Wurrkos is shorter than an FWAA, but it would be nice to have a side-by-side photo to compare.
Mine just arrived ,11 days to uk , super fast delivery.
I like it very much ,Its smaller than I expected ,good to hold waisted machining makes it easy to hold and doesn’t slip from your grip.
Button grey anodised alloy ,I guess ,nice feel ,positive slightly firm click ,probably nicer button feel than original FW3a.
Tint is cool white but I like that!!! That said it’s not blue ,cool white is not what it used to be!
Never had a reverse clip and didn’t think I would like it ,not being a cap wearer ,but it’s Ok and will keep it on the light.
Aux lights in lens ,Again never had that , I like them ,were set on high out of the box ,set them to low ,better for me.
Anyone know what chemistry the battery supplied with it is? Wurkkos branded 900mah.
Beam profile very close to FW3a
It gets hot quick ,but it would it’s tiny!
Overall very happy with it , especially at the price point.
TS10 with popular lights for size comparison
This sounds very promising.
One of the issues with the FWAA is the beam profile is too floody. Sounds like Wurrkos might have a real winner on their hands! :sunglasses:
Does the board need to be removed in order to flash? or can it be done while in place?
No, you have access to the flashing pads after removing the battery tube.
thanks for the photo of the TS10 flashing pads (I used a clip of your pic below)… looks like they will work with the TTL Pogo adapter that gchart made for the SP10 Pro…
note the TTL is modded by gchart, it is not stock
I would like it please… should I pm you my email? might be good to give it to Wurkkos too :wink:
I have the programmer for the kr4 that was stolen from my house… Would that work?
