thanks for trying… to help
my mac is on Sierra 10.12.6
is this supposed to be two separate commands:
ls /dev/tty.usb*
/dev/tty.usbserial-ftDI
it shows up as 2 separate lines in your post
ls /dev/tty.usb*
Updated my post to clarify, the second line is the output you should get it the usb serial has been recognised.
“ftDI” is a placeholder for the serial number of the device.
understood, thanks
so yes, youre right, my mac is not able to see the TTL
it just responds with
ls: /dev/tty.usb*: No such file or directory
thanks again for trying to help… Im going to stop bashing my head against the wall for now… enjoy your Sunday, and
Happy Fathers day to all
Do you have access to any other computers? (A raspberry pi for example?)
no, just this 2015 iMac…
Do I need to buy a new computer to be able to flash Anduril?
> only certain USB serial adapters that contain an FTDI chipset work on MacOS Monterey and higher.
or maybe just a different TTL Programmer?
I just noticed that you said your mac is on Sierra 10.12
Can you try these instructions? They apply to the CH340 chip you have on Mac versions earlier than Mojave 10.14
thanks for the suggestion… might give it a try later… much appreciated
Jon, what CRI does your Opple measure?
99.5 Ra at 5509 CCT… but Im waiting for someone w a spectrometer to measure R9, and confirm the other values
Nice, thank you
I thought my Opple was nuts… I get 99.6 CRI! This is the first 5800+k light that I actually am inclined to like. The output is so clean and so white that it does not hurt my eyes.
Definitely a fun little light. I like that the TS10 beam throws more, is less floody, than my FWAA.
I just ordered a Red TS10 w 4000K LEDs and Red Aux lights… woohoo!
I just ordered a Red TS10 w 4000K LEDs…
Me too. I haven’t even gotten the ts10’s I ordered on June 6 yet and I just did the same!
Unheard:Jon, what CRI does your Opple measure?
I suspect the LEDs in the Ts10 are the same as the Wuben F5 NW tint setting…an advertised as 5700k, but I get about 5500k and 99 CRI. I dont think it’s possible, but maybe it’s close? It’s within 5%.
> What does 150/150 actually mean?
Anduril has 150 steps from lowest to highest output.
150/150 = highest = turbo,
1/150 = lowest
Boy was I wrong about the tint being too bright for a tiny light, dang near perfect light the only issue being the aux lights…Thanks Wurkkos the TS10 is best in class imo and like many of you guys I also ordered 4k red on red.
What “issue”?
GleamBeam:the only issue being the aux lights
What “issue”?
Turn the aux off , put TS10 in moonlight and take a look.
That behavior is just on flashed file away from being fixed and getting the latest Anduril 2 features. I could not live without 3C unlock to off. The switch is a little less sensitive than it could be, but otherwise it is fantastic.
Has anyone opened this yet? I wonder if aux-leds should be like that where two of them are kinda behind the optics, but one is more freely between?
I have, see my post on reddit
As you can see, the aux leds are fixed on the MCPCB.
