I’m trying to hold out for purple or blue body before I order another one…
> Yeah, ordered a red 4000K before they’re gone again
me too, red is the best w red aux… lol
Yup, ordered red/red at 4000k today as well. I hope the 4000k is as good as the 5800k
Will orange, blue, or green release? I’m sure some of us want to match the aux to the body color
I ordered one in black/orange aux/4000K on their AliExpress store. I was waiting for something warmer than 5800K-6000K. I hope the one I get also has 90 CRI and isn’t below 4000K.
When I click the link for the 4000K version on Aliexpress I just get a message saying it can't be delivered to Germany. That's weird, I ordered from Wurkkos without issues. Do you want my money or not? xD
Oh right, I keep forgetting that the ATTiny /Anduril uses the voltage on the Vcc pin for this :person_facepalming:
When I click the link for the 4000K version on Aliexpress I just get a message saying it can’t be delivered to Germany. That’s weird, I ordered from Wurkkos without issues. Do you want my money or not? xD
oh ,that maybe some bugs, to Germany without problem, i will check with the our aliexpress salesman
@Wurkkos, I know this is asking a bit much, but could you make a high end version of the TS10 with MAO anodizing?
That would look absolutely sick.
This might be THE BEST new light that came this year.
I might have to agree with that statement. One big strike is the lack of 3535 emitters.
Can’t wait to try out this light. Mine is listed as “out for delivery” so fingers crossed it arrives today.
Was there a code for Aliexpress?
Code:WKTS10220620, –1.5 dollar
Package content for 3 choice:
without battery charger: 1 flashlight, 1 user manual, 1 lanyard, 1 clip, 2 replace orings
with battery: 1 flashlight, 1 user manual, 1 lanyard, 1 clip, 2 replace orings, 1* 14500 900mah battery
with battery charger:1 flashlight, 1 user manual, 1 lanyard, 1 clip, 2 replace orings, 1* 14500 900mah battery,1 usb charger
Mine should be here tomorrow. Looking forward to it. Will post a few words once it is here and I have played with it a bit.
From the pics, I am already loving the size.
What is wrong with the clip?? (ahhh… the oft hated bi-directional clip) Same type on my current favorite 14500, the SP10 Pro. Not a favorite of mine, but handy in certain situations… and it works fine.
- It’s a 2-way clip - yes, they’re the fad that all manufacturers seem to be sticking on their lights these days, but I hate them. The only advantage a 2-way clip has over a 1-way clip is that you can stick it on a ball-cap. But if you’re like me and don’t wear ball caps that benefit is completely lost … a good 1-way clip should always be better.
- The extra bend of 2-way clips sometimes gets caught on things in a pocket when the light is withdrawn from a pocket. I haven’t checked to see if that is an issue with the TS10’s clip, but it was an issue with the FWAA’s clip.
- The bottom of the TS10’s clip lacks an angled bend to allow the clip to ride up over the edge of a pocket or belt when the light is clipped to something. Result is clipping the light onto anything is a 2-handed operation: one hand to lift the end of the clip up, while the other holds the light. This is inherently less convenient than a clip with an angled lip at the tip to allow the light to be clipped to something with just one hand.
- If you only ever use your light bezel-down, the extra bend of a 2-way clip means extra unneeded weight is being carried around.
- If you only ever use your light bezel-down, the extra bend of a 2-way clip means the clip is sticking out further from the flashlight body than needed, making the light less compact.
Have you ever hooked the end of your (non-bi directional) clip on something like a shirt tail or coat and accidentally pulled it out? I have, a bunch of times and lost lights because of it. The rounded leading edge of this clip looks like it is far less prone to getting snagged on something and pulled out of your pocket.
Just something to think about.
How is regulation on the light?
Does it use a linear style driver or is it all DD FET?
It’s FET+1x7135 :
I received a DOA TS10 3 days ago, aux LEDs work but not the main emitters. I promptly wrote to support email address but got no answer, any idea how to have it replaced?
While holding the button down do the main LEDs light up dimly? If so, then the problem is lockout is activated and you just need to click 4x to unlock the light.
The next most likely culprit is the connection between the switch and the driver. Make sure the head is screwed all the way down. If the head isn’t screwed in enough, the inner tube won’t make contact and the switch won’t work. Result is the aux leds will be on, but the switch won’t do anything and the main LEDs won’t light.
How long is the 14500 battery you are using? If it is too long, it is possible that it is preventing the head from screwing down all the way. In that case, the light isn’t broken but it won’t work either. You would need to get shorter batteries.
If none of that works, then something internal is probably broken or not connecting. The problem might be something relatively simple to fix like a loose driver wire. Or it could be something much harder like a broken or improperly soldered FET.
