Update: 2022/12/8
MUO Best Tech of 2022 Awards! ACEBEAM is proud to announce that The MUO has awarded us the Best Flashlight 2022 last week. Our brand new X75 was the light to earn top honors.
Learn more: https://www.makeuseof.com/makeuseof-best-of-2022-awards-part-two
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
The new extra-large capacity battery pack is fully prepared for search and rescue, specially designed for high power flashlight X75.This battery pack is made of 8 pieces 21700 Li-ion rechargeable batteries with high capacity and performance, safety features.
Learn more: https://www.acebeam.com/extra-x75-battery-pack-821700
Updated: 2022/11/8
Acebeam X75-The worldβs brightest 80000-lumen PD power bank LED flashlight VS W50-The worldβs professional longest throw LEP flashlight that features almost 4 kilometers. (Laser Excited Phosphor).
Read more:
_
βThis is the best high-power flashlight Iβve ever used, with almost 80,000 lumens of output, and a sustained 20,000 lumens with a high-efficiency driver and advanced cooling system. Though itβs pricey at $400, the Acebeam X75 represents excellent value for its performance and build quality - if you want to the best super flashlight, this is it!β commented by LuxWad
Read more:[video: https://www.youtube.com/watch?v=7lqzdO3eTow]
_
βIβm particularly impressed with the Acebeam X75βs build quality, power bank mode, and size. This X75 flashlight is more practical, much more waterproof (submersible to 1.5m), 600 grams lighter and $270 cheaperβ¦.β Commented by Wellrigged
Read more: https://bit.ly/3SXST9L
_
Updated 2022/10/24
Can we use Flashlights for Filmmaking and Photography?
βThe X75 in additional to ACEBEAMβs strongest light,X50 CRI flashlights also can be used perfectly for Filmmaking & Photography because of their Color Rendering Index (CRI) of 95.β From FilmmakerβChristian Mate Grab
Updated 2022/8/27
ACEBEAM X75 Limited Edition Off-White Micro-arc Oxidation (Available on 15th Sep)
The X75 High Performance Outdoor Flashlight achieves IP68 waterproof rating, can resist 1 meters impact, is rugged and durable, can meet different needs of lighting situations, and is your outdoor lighting reliable partner.
Learn more: https://www.acebeam.com/x75
New Announcement: The Acebeam X75 is Brightest Power Bank flashlight in its class ( built-in 4 x 21700) , and the flagship flashlight of the Acebeam X series. Also the new X75 is the worldβs first USB PD flashlight with supporting 100W rechargeable system which saves you more time. After more than 1 year of development, our innovative development team has worked tirelessly to optimise the efficiency of the circuit up to 98% in order to produce as much light as possible.The X75 is a rechargeable searching LED flashlight with delivering astonishing 80,000 max lumens, a wide beam angle momentary Turbo and strobe function are quite ideal for security, law enforcement,search and rescue.
Lighting up a park!!
Features:
1) 80,000 lumens max output.
2) USB Type-C PD60W fast charging (Standard); 1.5 hours for full charging. Also can compatible PD100W fast charging(Max); 1 hour for full charging.
3) Built-in dual intelligent temperature regulation systems.
4) Intelligent cooling fan and Intelligent thermal control module.
5) Detachable, maintainable and waterproof cooling fan(IP68).
6) Can set the Windy mode or Non-wind mode.
7) Up to 98% high efficient constant current circuit.
8) Momentary Turbo activation rapidly responds to emergency situations.
9) Pure copper heat dissipation piece for high efficient heat dissipation.
10) Color-changing silicone sleeve monitors the temperature of the flashlight and protects for anti-impact.
11) Patented mechanical safe lock - No accidental activation.
12) IP68 standard waterproof.
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
This new X75 is the built-in battery pack (4 x 21700 ) brightest LED searchlight, features 12 CREE LEDs, and along with a wide reflector it produces an unprecedented 80,000 Lumens!
The X75 High Power flashlight utilizes boost circuit; innovative intelligent cooling fan for efficient heat dissipation, scientific cooling air duct design, detachable and maintainable cooling fan, and Type-C PD60~100W charging/discharging function - a truly uncompromising solution for the demanding professional user.
This tremendous power is focused through that reflector and can reach distances of up to 1150 meters (3773 feet), perfect for long range spotting as well as intense search and rescue operations.
