High current efficiency between 6Vout and 12Vout is mostly the same at the same power, same Vin, it’s just the peak efficiency that is a bit higher at 6Vout, about 1~2 percent points higher, which isn’t a lot, that is if the same inductance is used (1.5uH in the case of the noctigon driver), normally you’d use a lower inductance for 6Vout, which would have lower DCR and a bit more efficiency at high current.
Aahh, Hank musta updated his website. Those numbers weren’t there when I emailed him.
I am just a little disappointed in the lumen output of the SBT90.2. I’m used to expecting 4500 plus lumen as the norm.
But I fully understand it must be because of the lack of mass and perhaps a limitation of a 18650 battery feeding the hungry LED or other factors.
Still planning on getting the light though. Love carrying around all that power and throw in my pocket.
SFT40 offer the optimal performance but I already have 3 lights with this emitter that can throw further. I have FC-40 in my convoy L6 and the beam is beautiful, but then again so is the D4S with 519A. Maybe I don’t need the D1 at all?
I planned to try the new XP-L Hi-version in this light. They probably allow more output, because of lower thermal resistance. So 4000K near 2000 lumen compact thrower could be possible.
Hmm now that I think about it, I already have the noctigon kr1 with sbt90. They are almost identical in size. I was assuming that the d1 mini had a smaller head.
What 18650 do you all recommend for my 519a D1? I’m assuming it doesn’t need as high of a discharge rate as my D4V2, so I could get away with something with a lower discharge rate but higher MaH rating?
Received my D1 with dedomed 4500K 519A today! The tint is absolutely beautiful and while I don’t have any fancy tint-o-meters, it’s a bit more cool/neutral than my 3500K 219B R9080 by about 200K.
I’ve read on Reddit somebody saying the 519A comes with an OP reflector by default, mine came with a smooth one, so I’d check with Hank before ordering if that’s important to you. The beam is a tad bit ringy in the corona, but it’s not too noticeable.
Can’t wait until tonight to get a better feel for the light.
It would be run to about 2.5 amps on 12 volts, so not too much, but it’s still like 2500 lumens or something like that. Plus it’s really efficient so good runtimes.
xhp70.3 HI will definitely have more efficiency and slightly more throw. The GT-FC40 usually offers better / more pleasing tint IME. though, the recent GT-FC40 4500k i have seen in some of the D1 i have modded have been plagued with yellow spots in the middle of the LES / Beam. I bought a GT-FC40 4500k D1 in July and the tint was VERY rosy. Sucks to see such inconsistency.. I have heard hanks 70.3 4000k measures well above BBL and is yellow. I have not heard anything about the newly added 3000k 90CRI 70.3 offering hank has though..
