【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
SammyHP, got your fork flashed on both of my TS10’s and love the low blink for lockout! Also the refactored low end ramp smoothness is awesome.
Thanks to both of you for your hard work on this firmware.
I’d say “half good” : it is both very good and not much :confounded:
It has really cool things going for it, but the clip is awful, it scratched the surface of the flashlight at first try.
I would have loved a deep-carry : so I made kind of one using old Wenger chained o-ring and modified original clip, but it scratches the body even worse than stock clip.
Anduril 2 is quite fun, but its one more UI to remember… I’d prefer it if there were two channels
I also succeeded in reflashing a TS10… Thanks to all
the lowest mode, in advanced, is now 0.02 instead of 0.2… YAY
aux lights are off when main LEDs are On… YAY!!!
defaults:
94 lumens memory at turn on, in Simple Mode, floor 0.2 lumens, ceiling 804 lumens. Aux on Low when Off. Aux on High Blink when locked.
advanced mode 2H from off gives ceiling 367 lumens, 2H again gives turbo 955 Lumens, floor is 0.02 lumens.
fwiw, I increased thermal step down to 50C, the light now sustains 300 lumens. In stock thermal config, the light steps down to 88 lumens in less than 10 seconds.
Where do I get the hardware to reflash the TS10?
I got it from gchart: (ignore the green circles)
the TS10 has no pin holes in the pads, so you need to clamp the pins to the head something like this:
thats actually a pic of an SP10 Pro, it has holes in the flashing pads, and does not need to be clamped, but I did anyway
the programmer also works for the SC21 Pro, with a separate harness…
I did not have pogo pins, I soldered the wires to the flashing pads on the driver. The wire harness I used for the SC21 Pro, came from a separate purchase on aliex…
all this thanks to Adair21’s post,
plus lots of help from several kind people who coached me privately to install all the software and driver, on my iMac.
If I purchase a TS10 say today, I wonder if these changes would or can be requested to be flashed to my unit? Not sure how it works between you guys….
Usually pogo pins are pointy enough to not slip away. You can hold it in place with one hand and use the other one to start flashing. Using a clamp makes it slower, but helps positioning if it is difficult for you to see the tiny pads or if you can’t hold still enough.
https://intl-outdoor.com/reflashing-kits.html.
Will this adapter work with ts10?
No, that one will not work. This post explains what you will need: 【TS10V2 Ti available】Wurkkos "slender waist" TS10 titanium version will available on 23th,Sep - #653 by gchart
I want to thank all the people, named and unnamed, that have helped me learn how to reflash Anduril 2 onto my TS10, SP10 Pro, and SC21 pro, including but not limited to: gchart, SammysHP, Adair21, zumlin, and BruisedMonkey.
album w more flashing photos https://imgur.com/a/TGeVkk2
I applaud you for bringing Lower Lows to my Anduril lights
my SC21 Pro, and TS10 now have lows of 0.02 lumens, 10x lower than before.
That change has Transformed my nightstand light options. Now I can use lights that were too bright, thanks to the Lower Lows you have created for us, and that gchart has incorporated into these Hex files that I used to reflash my SC21 Pro, SP10 Pro, and TS10.
hex file sources:
major thanks to the_gchart and SammysHP
TS10 https://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.2022-07-19.wurkkos-ts10.hex
turns off aux lights when main leds are on, adds LVP to aux light circuit, AND makes the lowest mode 0.02 instead of 0.2 lumens
SP10 Pro https://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.2022-07-23.sofirn-sp10-pro.hex
eliminates the blink at top of ramp.
SC21 Pro http://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.2022.07-20.sofirn-sp36-t1616.hex
converts from Anduril 1 to Anduril 2, adds LVP to button lights, plus makes the lowest mode 0.02 instead of 0.2
Thank You All! :beer:
Thanks!
Oh, that’s not the “ZebraLight low”. It can go much lower, but I don’t know how reliable it would be.
It is 10x lower than before, Im very happy.
fwiw, the lowest low on a zebra SC64c LE specs is 0.05 Lm, and Im getting 0.02 Lm from the TS10 and SC21 Pro. The SP10 Pro is 0.01 Lm, on my meter…
Thank you. i thought i would buy the complete adapter
contact thefreeman
I was writing. He has no time now.
Anyone sell the complete adapter in u.s.
Yes, I have adapters. PM me, please.
Hopefully we can get a manufacturer for these soon.
I’m quite late to the TS10 party as Wurkkos doesn’t sell it in China yet. I had to get it through some back channels :smiley:
I will test the TS10 Aux lights but the drain claimed in this thread seems too high.
I’ve tested my D4v2 with cyan Aux on high for 2 months and it drained my Samsung 30Q from 4.18V down to 3.81V so it would take 7 months to fully drain the battery. The drain actually tends to slow over time because the Aux lights lose some brightness as voltage drops.
By the way, I found the best way to use a USB ASP is with jumper cables. ファイル:A few Jumper Wires.jpg - Wikipedia
You don’t need to solder wires or use pogo pins. You can just electrical tape the end together to the right configuration and then put enough pressure to make contact with the electrical pads.
Has anyone tested the max current the light can put out, especially with high drain 14500s? Testing current draw for tail E-switch lights is always tricky and I’ve given up on it.
I suspect the light can get up to 2000 lumens at turn on with high drain 14500s.
Copper flashlight, whether there are oxidation spots on the surface of the light, when received?
Brass not have this problem?
