Operation Instructions of WK40
WK40 with dual switches, tail switch for modes changing and ring magnet switch for brightness.
3 Groups:
Group 1: white lighting mode (default)
Full click to turn ON/OFF, Rotate the magnetic control switch for brightness adjustment: low-medium-high-turbo.
Double half press to strobe mode, the other half press to return.
When ON, triple half press taggle to Group 2.
Group 2: Color mode
When ON, half press to cycle different colors: green-white-blue-red, rotate the magnetic control switch for brightness adjustment: low-medium-high-turbo.
Double half press to strobe mode on each color, the other half click to return.
When ON, triple half press taggle to Group 3.
Group 3: Flash mode
When in Colorful gradient mode, half press to lock the color when gradient, another half press to return.
Colorful infinite gradient:The gradation cycle is about 15 seconds, and the three leds of red, green and blue are dimming and cyclic light distribution, and the magnetic control ring is rotated to adjust the brightness.
Police flash: red-red→blue-blue→red-red→green-green→cycle, each color flashes at 4HZ.
Color changing flash: red→green→blue→white→cycle, each color performs 6HZ flashing with a cycle of 1S.
Color changing slow flashing: use red→green→blue→→cycle, each color flashes at 2HZ with a cycle of 1S.
When ON, quickly half press the tail switch twice to change flash modes: Colorful infinite gradient→ police flash → color changing burst flash → color changing slow flash → cycle.
When ON, triple quickly half press the tail switch enter the white lighting mode.
The Wurkkos TS22 looks like a very interesting light, I would like the manufacturer to also release a technically identical headlamp with a boost driver, 21700 cell and LED xhp70.2 or xhp70.3 hi
Would love to try the WK40 for light painting photography! Excellent choice on the RGB Luminus emitters Wurkkos, in combination with rotary switch I’m sure I could pull off some unbelievable pics!
Very Interesting Nice Lights especially the WK40 !
Wurkkos Lights i have : TS30S,WK30,TS10 Red with Green Aux,HD15R in Red,TS30 6000k. And i ordered the HD15 4000k a few days ago.
I also had the FC12 in Champagne which i gave to my Mother as a gift, and the FC11 5000k in Purple which i gave my Grandmother as a gift.
I’ve got an FC11, will probably pick up a TS10 at some point when the Red is back in stock.
For the TS22, it would be great if you could off it in the XHP70.3 HI. The High Intensity is just better suited for flashlight use, with higher candela and less tint shift. If you could get some in 90 CRI (I’ve heard the 5700K is actually supposed to be quite nice) that would be even better.
