Ooooh. I like that D4k !!
but… I just had a thought… D4S with a longer tube for those 26800? 26900? cells…
I’m going to have to figure out a way to get a D4k on my Christmas list.
*edit
Oh! it is a thing!
*edit
Oh! it is a thing!
Yes…the 26800 tube is a thing! The one I got matched the cyan of the original perfectly. I love the 26800 cells (QB from Aloft), hope they stick around as a thing in the future.
That actually sounds really compelling when you put it that way. The plan is to get at least two D4K lights eventually but I’ve been undecided on my configurations. I think one of them may end up having a boost driver now.
Same! The D4SV2 with 26800 tubes are absolutely stellar. I consider them a Goldilocks size for a jacket pocket light.
I can’t see the option for the 21700 D1 ??
I considered the SST20 in 5K, which I think is actually still a pretty nice emitter all things considered, but for this I wanted a tad warmer without going Warm. I’m often dealing with metal in one way or another and not-cold CCT just works better for me in trying to see detail, textures, scribe lines, etc, etc. It seems to help me reading finer graduations on scales, too, and pencil or ink lines usually. Sometimes whiter is better though. For just knocking around and putting light out there, I can live with nearly anything.
Pretty sure there isn’t that option.
Is D18 update with higher efficiency driver planned?
Hi, Dear DM1.12 owners, you can use the firmware below to enable both channels to work at the same time (even on turbo mode),
http://toykeeper.net/torches/fsm/anduril2/anduril.2021-12-13.emisar-d4sv2-tintramp-fet.hex
Awesome! Thanks Hank!
Any plans to offer E21A/E17A with boost driver option? Seems like a natural fit
8x365nm mule is crazy.
You can feel the eye pain when you turn it to the max:)
I wonder how much true 365nm UV power do those 5W leds have.
I know Nichia had like 1.5W, but it was almost completely pure UV. These 5W Seol leds produce much more blue light than Nichia
The 26800 cell is impressive for mAh and amperage capability. But out of the two chargers I’ve got, none can fit that large a cell. And since there’s no built-in charging, that means investing in a new charger… so 26650 is about it for me (SP33v3 host w/charging). What charger do you use for your cells, Correllux?
_
I was all set to buy a DM11, but then the colors ran out (no more green or gray). According to Hank, black is it for the remainder of the production. But in a way, this was good. It halted me from getting it and turned my attention to the D1.
Frankly, the D1 looks to me like a Lumintop GT Mini but with the advantages of Anduril, superior body, shorter length, and better LED choices. PLUS, the D1 has the option for RGB backlit e-button. While I was starting to shift my flashlight interest into 21700 and larger cells, 18650 still does the job, and the D1 offers so much for this form factor. Starting price is very attractive too. I was thinking of the SFT-40, which adds a mere $5… but then, saw the XHP70.3 now available, for another $10 over the SFT-40. Yeah, I’ll pay that much for bespoke CCT. I’m sold on the XHP70.3 5000k. Seems like a very good fit for this mini thrower. While a W1 or W2 is going to reach some impressive distances, that tiny hotspot isn’t all that useful at the outer end. I’d rather the range be a little shorter but with a larger hotspot and more usable spill.
Anyway, if anyone here has the D1 with XHP70.3 in 5000k, please chime in and share your impressions. Thanks!
I have two lights with onboard charging…26650 but both made the 26800 tubes available, so that makes it easy. M3C and FT03. I made an adapter sled for my usual Miboxer charger using the 26650 cradles that I split (for elongation) and mounted to a wood block with soldered 10ga stranded wires and a dummy cell, which works very well but is a little fiddly, so I’ve been mostly charging in the lights. If Vapcell follows through on an updated charger that takes these cells, I’ll buy one as long as it’s decent. Xtar did bring out that single cell charger for 26800 which I think without coupon was around $14, have to order it from China, though…they didn’t seem interested in stocking it in the US for some reason but maybe that’s changed, or will change. I think Yonii introduced a single cell unit as well and hopefully they’ve improved its faults. I was half hoping that maybe Astrolux/Banggood would update one of theirs but it doesn’t look like that will happen, and it also doesn’t look like Xtar will bring out a more fully featured 26800 bay charger.
I just realised that the 365nm 8x5W mule may not be very useful as I thought.
Because there is no throw compared to a Convoy for example. And having it floody and at max output does not produce any advantage over a single 5W 365nm light. On the contrary hurts the eyes like hell.
Maybe I missed it, but what driver is in the dual channel D4K? I can’t find what max regulated is.
What’s the actual limitation? The 8A amperage of the boost driver (quad E21A should be fine at 8A though) or something with the board being parallel or not?
Which type of driver is used each LED offering for the D1V2 again? I think I remember the FC-40 gets a boost driver but I can’t remember the rest.
Hello, I just received my D1, with an RGB switch, but I don’t know how to control that button, to choose the color and so that it doesn’t stay on.
I also think I’ve read that it can tell the battery voltage, but I’m not sure.
I hope someone can give me a little help.
Thank you very much, greetings.
In July 2020, ToyKeeper, posted on BudgetLightForum about work on Anduril 2: a major rewrite of the Anduril 1 firmware. Based on the original text manual found in the source code, this is a formatted version of that manual for easy readability on...
