Not one reason:
*my motivation for the hobby was in part coupled to the lightning fast development of leds from 2011-2018, developments since then are much slower, not much gain anymore. Except for LEP but LEP modules are expensive, are difficult to mod with and are already fairly optimally used in stock lights (not like back then, we made throwers that throwed more than twice as far as any stock light). I may have a go at those though.
*several big developments in the world make me worry, for me worries are not good for hobby.
*our son’s health has been pretty bad for half a year. But he is much better now
My heart goes out to your family, best wishes for your son’s continued recovery.
Sorry to hear, dont worry too much Jos, if you need a listening ear, you can always contact me.
Health always goes first, good to hear that his healthyness is improving!
What a nice way to breathe new life into something with such sentimental attachment and a real working history!
You could put a nice high CRI emitter on the front end of that handle, you know….
… with a pressure switch.
Chop veggies in a dark room, let the kiddo sleep.
Found a mod I may attempt this winter and thought you may enjoy this one: https://gaggiuino.github.io/
Arduino controlled espresso maker mod. I know we have quite a coffee thread going on here with some connoisseurs.
I’d like to see how this comes out. I have a Rancilio Silvia that I modded with a PID kit. Been using it every day since 2006, still going strong.
Long time… years… since I did anything FL related.
My modded L6 went to a better home a long time ago and while I had the parts I never did make another.
L6 with 70.3 4000K and Mtn Fet+1 D4 ramping. Also made the E-SW light. But still to bright IMO. Kinda quit after 6 resistor swaps. Kept the OP reflector but I do have SMO to try again. Wasn’t happy with last SMO on the stock light.
Took the L6 apart and this was the first thing I found. Emitter shelf has black anno and someone took a grinder to the emitter base surface. GRRR this build just got Longer.
Got it lapped flat after some time…
E-SW still a bit too bright in complete dark
But not that bad in day in daylight.
ML is nice with 4 squares looking even.
Pretty happy with the Spot. Pulls 17A at tailcap for over 15sec till it starts dropping, Old Lii50A black. Haven’t messed with thermals and probably wont.
Nice VWP, the L6 is a very sweet host! I too just put one together, mine is a stubby with a single cell tube from an L2 and utilizing an SFT40 emitter. Richard built the driver, I flashed it with Anduril.
Intended to use an 90.2, 20mm shelf needs to be larger. Not up to doing that at this time hence plan B. Lol
Makes me realize just how much work I used to put into lights!
Looks very nice, congrats!
More playing with the L6…
Trying to flash Anduril to the MtnE 30mm Fet+1 tiny85 for 2S config. I tried the “anduril.2021-12-13.emisar-d4.hex” file and could not get it to run full turbo. Was only drawing about 4A with on and 2C. Tried again with “anduril.2020-03-18.emisar-d4.hex” file and got it back to 17A on full turbo.
Was like it wasn’t kicking in the Fet…
Any hints here?
Anyway it seems fine now.
Is one Anduril 1 and one Anduril 2? Turbo behavior has changed in Anduril 2. To get turbo, first ramp up to ceiling, then do 2C. It can be changed in the config menu, check the manual.
Hello Sammy, I tried the ramp to top and 2C but there still was no change in brightness. Same files again on another light with another MtnE 17mm Fet+1 tiny85, but this light is a triple running 1S. Flashed it back to the 2020 file and it will run turbo ON and 2C. Same problem on 2 different lights with same files used.
I did check the Anduril2 directory of files and there were none that match these dates. I do see the “Anduril2” files in that folder do not use the “2” in the names but I did not get these from that directory. This Anduril is new to me and thanks for the tips.
Just finished this one today. Old C8F 18650 host. Now has XPL-HI 5000K and the MtnE Fet+1 on Anduril.
More old parts getting used up.
padded case takes up too much space, best I could come up with for drawer storage
Very nice looking beam profile, congrats on your mod.
Thrunite Ti3 Ti Hi
stock:
mod to sw45k:
Thanks Jon, that TI3 is looking pretty sweet now.
Little more thought on my firmware flash after reading all the recent posts on Anduril “issues”. The newer version just might flash to muggle mode with no turbo. But I’m still learning Anduril so I would bet that I am the Issue. Wires on the C8F and the L6 are just barely long enough to get the driver flipped and clipped for flash. Will try again.
Need to ditch the Green SW LED on the C8F anyway… back to the bench.
tickled Pink I am w the Ti3, thanks
hope you make good progress w your mod and Anduril learning curve
happy to brainstorm Anduril Options, PM any time
Thanks for the offer Jon. I tried again on the 2021 file and also tried to to see if it was Muggle mode. I was able to access other functions so I am inclined to think it was not in Muggle mode and NO Turbo once again. 6C, same same… Just went back to the 2020 file I know works.
Went white behind the smoke black button. I like it…
Hand soldering.
I modded my BLF LT1 lantern with a new board from Lampman who restarted his business in Norway, much fun, more details here:
The posts i see are about someone’s personal issues with Anduril 2 rather than issues within the firmware.
Anduril 1 had muggle mode, Anduril 2 is quite different and is built around 2 UIs, Simple UI and Advanced UI. Simple UI is a properly performing UI with more functions than muggle mode, possibly including those functions you accessed.
In Anduril 2, if you’re not at the top of the ramp 2C will take you there. Once you’re at the top of the ramp 2C will take you to turbo in Advanced UI, but there is no turbo in the Simple UI so 2C will not change the brightness level from the top of the ramp.
If you’ve just flashed the firmware it will have defaulted to Simple UI (intentionally) which would give you more functions than muggle mode and no turbo, which sounds similar to what you experienced.
Also, 6C is only relevant to Anduril 1, it does not switch between UIs in Anduril 2. (That’s 10H for Simple -> Advanced, and 10C for Advanced -> Simple.)
Is it possible there’s a misunderstanding with how the new firmware functions rather than a fault with the firmware itself?
Here are some UI flow diagrams for Anduril 2:
https://budgetlightforum.com/t/-/65927
This is a link to the text version of the manual:
https://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
TK’s Anduril 2 thread:
https://budgetlightforum.com/t/-/62656
