@Buwuve: Yup, you’d probably pay the same here in Spain. That’s why I buy most things from China :bigsmile:
@hank: now that’s a really good price, mate AFAIK, PWS doesn’t offer free shipping (unless specified), but I wouldn’t mind to pay 5 bucks more for shipping BTW, here is the link. Thanks again
- Yellowhorse: don’t know if that size exists, but don’t worry, SP2 will charge it w/o any prob It will charge any li-ion cell. Only those small ones, i.e.10440 or 16350, should been charged @0.5A (IMHO) only and with caution.
@HKJ: is that me, or this charger doesn’t have any noise? (compare them to WP2 or I4 and see the diff)
SashiX - No doubt it will charge a 18370 lithium battery if it existed. I was just trying to clarify/correct the chart that was posted. I know HKJ wouldn’t want any mistakes/typo’s to remain.
Appears to be a real upgrade to previous chargers made by Xtar. I like the adjustable amperage settings and the fact it will do 26650’s without having to tinker with it. Also nice to have another charger with CC/CV AND termination at the end of the charge cycle. If I wasn’t already overloaded with very good chargers, I would buy this one.
Cells discharged below 2.8V are considered not safe. Should not the charger provide at least an indication of the fact? Perhaps the charger should not charge them?
This depends on the cell, the current Panasonic 2900/3100/3400 can be discharged down to 2.5 volt.
I believe that Panasonic specify that you must soft charge below 2.8 volt.
One of the problems with LiIon safety is that the limits are depend on the actual cell used, this is no problem in a full battery pack with the charger build in, but it a problem when using a loose battery. It would be more safe if it did not charge below a low limit, but then there would be problems with tripped protections and depending on limit, some types of cells.
At low voltage it will use a very low current, that does not really charge the battery, but will reset protection, you can also see that the light stays green instead of showing red for charge.
The charger is not more dangerous than many other chargers on the market, many chargers supplies some current at low voltage, often more than this charger.
That low voltage may rise quickly, even with very low current.
Perhaps the 4.23V also should not be dismissed so easily, some people cry “Terrible!” at seeing 4.23V.
Some people does, without even reading a data sheet for a LiIon battery or knowing how to measure the charger voltage (This is not the same as the battery voltage, when the charging is stopped).
As long as the voltage is within the limits in the LiIon data sheet, I will not call it a problem.
The current on this charger is mostly stable, there is only small variations while the charger is adjust it, no switching between 0 and full charger current.
IMO there has been really low amount of failure reports on WP2 II and I presume there are a TON of them in use just on this forum alone.
I remember reading this one and one before.
I would still say it is above average and not by a smallest margin.
