Cells discharged below 2.8V are considered not safe. Should not the charger provide at least an indication of the fact? Perhaps the charger should not charge them?
This depends on the cell, the current Panasonic 2900/3100/3400 can be discharged down to 2.5 volt.
I believe that Panasonic specify that you must soft charge below 2.8 volt.
One of the problems with LiIon safety is that the limits are depend on the actual cell used, this is no problem in a full battery pack with the charger build in, but it a problem when using a loose battery. It would be more safe if it did not charge below a low limit, but then there would be problems with tripped protections and depending on limit, some types of cells.
At low voltage it will use a very low current, that does not really charge the battery, but will reset protection, you can also see that the light stays green instead of showing red for charge.
The charger is not more dangerous than many other chargers on the market, many chargers supplies some current at low voltage, often more than this charger.
That low voltage may rise quickly, even with very low current.
Perhaps the 4.23V also should not be dismissed so easily, some people cry “Terrible!” at seeing 4.23V.
Some people does, without even reading a data sheet for a LiIon battery or knowing how to measure the charger voltage (This is not the same as the battery voltage, when the charging is stopped).
As long as the voltage is within the limits in the LiIon data sheet, I will not call it a problem.
The current on this charger is mostly stable, there is only small variations while the charger is adjust it, no switching between 0 and full charger current.
IMO there has been really low amount of failure reports on WP2 II and I presume there are a TON of them in use just on this forum alone.
I remember reading this one and one before.
I would still say it is above average and not by a smallest margin.
I had no hesitation in ordering the same as a replacement since there really isn’t anything better available for under $20. It started acting up with one side not starting a charge unless a cell was in the other bay. Then, finally it went into blink mode. I suspect these could use a bit more ventilation.
Two Xtar chargers @ $20 each plus your time and shipping = one Pila. If you do it right the first time, you win. I’ve had a pair of heavily used Pila’s for over 3 years with no problems at all. Some corners aren’t worth cutting. JMO
At the moment, I have ordered maybe 6 Xtar chargers, have not counted recently...
All still working. 6 x Pila would have been ~240$.
But I have to say, these all are for leisure / hobby use, flashlight use. Not professional use.
Sometimes I do not cut corners, had generic c*** AA-charger and got frustrated (batteries were eventually the fault) got MAHA & Eneloops straight away :) Needless to say - They Just Work!!
