As Troop said, Costco - I just purchased a set there today. The deal isn’t as good as it was last spring, but still not bad…10 AA or AAA’s for $20. I’ve found Duraloops at Walmart, but you have to look closely…they are Duracell rechargeables…you have to look for samples that say ‘made in Japan’ and have a white top. The others are gray top and made in China…but as I understand, these are the real deal. Wally World gets just under $12 for 4.
Hi friend,thanks for your great information,I am summer,I found your post today ,and would you like send your order nubmer to me ? I need help you confirm ,and our cs also need treat every customer as their God,and if you have anything about your order items,you can find our oneline chat ,and if they donot help you solve ,you can let me know ,ok ?
And I will treat every people as my dear friend,so please let me know your order problem,and then will help you solve .
have a great day
summer
Again, guys, these batteries are normal (crappy) chinese Ni-Mh cells with NO low self discharge technology, with a capacity around 2200mAh and they are not good under high loads (more than 1 Amp)
These are actually pretty good by cheapies standard. The crappy NiMH around were ~500-600mAh and discharge ~1C only. Of course LSD not included. By comparison, this fake is improved by leaps and bounds.
If they're priced at $5-$6 as they should be, and carry own brand, I don't think they'd have problem selling it. Hot cakes. Even I would jump on some for my kids battery packs and such.
The problem is they ride on Eneloops name and ruin it all.
How many people are being scammed by these fakes. DD should change the description immediately to FAKE-nloops to restore some credibility. A very low act imo. Bring back the Avoid label.
I have received "Eneloops" from Manafont,they are sightly different than Dinodirect's, they weight 27 grams each (heavier than DD's), they don't have the words WAHS and WATHER, but they are not genuine.
They don't have the Date Code on the side, and capacity isn't like an original one.
My Results:
Discharge to 0.8V @ 2Amps: 177mAh
Discharge to 0.8V @ 1Amp: 1703mAh
So… FAKE cells, but could be worse. MF Manafont doesn’t sell genuine Sanyo Eneloops!!!!
FX-32, mind doing one more test - discharging at 2A down to 0.1V? I’m wondering if this low capacity result is caused by their internal resistance or just crappy chemistry…
