Last updated 04.09.2013, see at the end of this post!
As some of you might have noticed I was crazy enough to order batteries from DinoDirect, their CS assured me that they have geniune 2nd generation UTGA AA Eneloops.
Since I had gift card or two I bought 3 packs with 4 batteries in each pack Ill just quote myself from original Eneloops thread where I shared my observations here: (quotes slightly modified to suit this thread) -it says GEN1, and not GEN2 on package contrary to what DinoDirect CS told me -wrapping is poor, see pictures below -definitely fake, avoid!
After initial discharge all batteries here are the results:
LINK TO FAULTY ITEM
Since I had gift card or two I bought 3 packs with 4 batteries in each pack Ill just quote myself from original Eneloops thread where I shared my observations here: (quotes slightly modified to suit this thread) -it says GEN1(UTG), and not GEN2(UTGA) on package contrary to what DinoDirect CS told me -wrapping is poor, see pictures below -definitely fake, avoid!
After initial discharge all batteries here are the results: 1587mAh 656mAh 190mAh 393mAh 1664mAh 1616mAh 1606mAh 703mAh 731mAh 719mAh 714mAh 1587mAh
Heres the packaging:
Wrappers are of poor quality:
Theres plenty of empty space between top of the battery and wrapping material:
Heres the bottom of batteries after removing them from charger once/twice:
I took the wrapper off one of the batteries:
Theres print on battery: HFR NI-MH 120417 Regarding their weight - they weigh as much as Turnigy AA LSD’s and gram or two more than my older 2nd generation UTGA AA Eneloops. When I discharged them at 1A they became rather warm, when I charged them at 2A they became really HOT to the touch, so I wouldnt say these are going to be reliable batteries I wont trust them and wont charge higher than @1A charge rate. Here are my numbers after charge-discharge cycle of my fake Eneloop’s from DinoDirect:
1-1823mAh 2-2183mAh 3-2313mAh 4-2015mAh
5-2409mAh 6-2278mAh 7-1966mAh 8-2109mAh
9-2530mAh 10-2420mAh 11-2468mAh 12-2370mAh
Initial discharge tests of 4 batteries after 2 days/~2weeks:
1-1895/1771mAh(1823mAh initial capacity when fully charged after 1 charge/discharge cycle) 2-2237/2064mAh(2183mAh initial capacity when fully charged after 1 charge/discharge cycle) 3-2356/2197mAh(2313mAh initial capacity when fully charged after 1 charge/discharge cycle) 4-2015/1790mAh(2015mAh initial capacity when fully charged after 1 charge/discharge cycle) 5-2409/1780mAh(2409mAh initial capacity when fully charged after 1 charge/discharge cycle) 6-2331/2143mAh(2278mAh initial capacity when fully charged after 1 charge/discharge cycle) 7-1966/1889mAh(1966mAh initial capacity when fully charged after 1 charge/discharge cycle) 8-2109/1909mAh(2109mAh initial capacity when fully charged after 1 charge/discharge cycle) 9-2416/2272mAh(2530mAh initial capacity when fully charged after 1 charge/discharge cycle) 10-2420/2094mAh(2420mAh initial capacity when fully charged after 1 charge/discharge cycle) 11-2388/2218mAh(2468mAh initial capacity when fully charged after 1 charge/discharge cycle) 12-2370/2162mAh(2370mAh initial capacity when fully charged after 1 charge/discharge cycle)
AVOID! DinoDirect was reluctant to give me full refund in form of gift cards, eventually they did give me 45$ gift card which is right about what I “spent” in their shop, actual amount was 11$ only, the rest were coupons and two gift cards. I used my newly issued 45$ gift card to buy 2xSysmax chargers
Updated@04.07.12 See post #26 regarding fake Eneloops received from Manafont as well! UPDATE - Manafont admits they are selling fake ones:
Sanyo Eneloop Mimic
UPDATED@ 04.09.2013:
I figured I should do discharge test on one of my Fakepoops after I tested it with battery voltage tester and noticed that its slightly below 1.30v, that got me curious since it was in the drawer for few months.
The battery was discharged at 300mA with MAHA C9000, discharge stopped at around 1.09v, I accidentally unplugged charger when it had almost 1700mAh discharged from it, after second discharge it showed 425mAh sucked out of it, so in total that makes around 2100mAh, last time I charged these batteries was probably somewhere around spring, thats the minimum period of time these batteries might have been in storage.
Battery number is IX=9, which was around 2530mAh fully charged when I reviewed them last year, back then it showed 2416/2272mAh capacity after 2 days of storage and ~2 weeks of storage.
So, losing ~400mAh after around 3 to 5 months of storage aint that bad.
Where these batteries suck big time is high load - they cant provide voltage neccessary, tried in my digital camera and even without flash it takes less than 20 shots for them to sag so badly that camera shuts down, the same happened with cheapo BTY rechargeables when tested.
Obviously, never so with original Eneloops!
So judging by one battery out of many my verdict is - good for low drain devices and not that bad in remaining capacity after some storage time.
Recommended? No, they suck for the money and are incosistent as phuck!
Thanks for reading!
