Looks like the thing is eating the O-rings.
I think that putting some silicone grease on the threads once a month will solve the problem.
So are you saying you measured it at 1800 lumens? Love the Magicshine!! But for over $260! Was surprised to see you could get it at Dealextreme.
I have a TR-DF003 where all joints ls body are HS! (4)
I have just changed by my personal seals and well sealed
I dont’ like to correct you, but most readers here might not understand the expression “HS”.
Just for those wondering about it. It means “out of order” (hors-service) and it’s a common expression for things that are not working, crap, badly worn or just good for the recycling bin.
Thanks for the clarification. I had no idea what he meant by that.
Seeing some beam shots would be great too.
Changing a driver will give us more current per led?
What Is the max lumens we can get from the light changing to better driver?
Hi Folks!
I’m still working on the deal and hope to have definitive news in a couple of days. I’m also wondering whether any of the scuba forums might have members who’d like to “hitch a ride” to this deal.
About the seals and the O-rings: Most divers know that the O-rings need to be checked every day they dive and that they should be lubricated at least every week of diving or every time the camera, flash or flashlight is opened. Those O-rings were definitely chewed up but it could have been caused by several things:
1)They could have been cut by dragging them over the threads during installation or because they’re too thick to fit past the interal threads.
2)They could simply have been worn due to lack of lubricant.
3)It looks like the O-rings may actually be too thick to fit in the channels (grooves) provided for them - once they’re compressed by joining the battery tube to the front and back.
4)They could have been torn because the interior of the front and back are overly rough (but the machining on this light seems too good for that to be the problem.
Looking at the photos, Option #3 seems the most likely cause. The channels (grooves) for the O-rings don’t seem to have any room (width) for the O-rings to expand into. Note that they already protrude well beyond the thread diameter - too much I think.
A good first-hand inspection should be able to shed some light on this.
Regards,
Bob
Yes. not too worried about that.
Still interested in the actual OTF lumens, because we’re seeing estimates between 1000 and 1800 lumens. An actual would be great.
If it’s towards the 1800 OTF, count me in on a buy.
Hello
on Ebay US
“Quality O-Rings for TrustFire TR-DF003 flashlight scuba dive diving plongée”
On 2 lamps in all 16 joints
out of order 13 and 3 good
“Je pense qu’ils montent des joints d’origine pour lampes terrestres et de plus non graissés”
I think that they get home for terrestrial lamps and more non-shaft joints
Hi folks,
I decided to order the light from AliExpress from this retailer, TrustFire TR-DF003 2x26650
They had trouble with my credit card and after 3 attempts, I was finally able to get the payment through, so I think they’re giving me faster shipping for my efforts. I don’t know if the Trustfire 5000mAh batteries are real ones, or how good the charger will actually be from them, but as long as the light itself is great, I can live with it. I’ll give a full report once I have it in hand.
thanks richie…Looking forward…
OK
The charger and Batteries trustFire are good.
Battery = 3800 mAh landfill under 2 (A) approximately.
Hence autonomy 1 h 50 min
(UltraFire is no good !)
Expenses to the o-rings (all) and to look at the lens and stretch (micro-coupures)
O-Rings here :
Still holding out for actual OTF lumens performance on this light. Can anyone measure?
It is impossible to measure (sphere) lumens
A lux or of candelas Yes!
Hello
3 eme lamp
total 8 o-ring
6 bad and 2 good !!!
UltraFire red
26650 5000mAh
2012 latest 2x 5000mAh 26650 3.7v Rechargeable Li-ON Flas…
Pseudo brotherhuang1983
reality
- 2100 mAh
and second
2400mAh !!!
Numéro de l’objet : 170828632814
My English is bad, but you are …… than me
Just for kidding :bigsmile:
New 26650 4000mAh 4.2V Lithium Rechargeable Battery Blue
in test : login “hittime_hk”
