Looks like a perfect mix of hotspot and spill now, very good! :bigsmile:
Would you say the exposure of the picture reflect the same amount of light your eyes were perceiving? If so that’s really a great offroad light for sure, the wait will be worth!
In the picture, was it still mounted on top of your DR Suzuki? I may be wrong, but light seems to be aimed slightly downward, and maybe it could result a bit more throw if aimed a little higher, don’t you?
The pictures are very close to what you actualy see.
Yes, these pics are taken with the light on the DRZ. I do have the light aimed down. Aiming it up did not gain any throw. It just took away the light righ inf ront of you.
Ok, understand what you mean. There would be some personal preference in choosing aiming, depending on terrain and use. Now hurry up and finish them, you have customers waiting! :bigsmile:
Aluminum, boards and components. I drove them up to the assemblers Yesterday. I should have them back in a week. Time to start machining on the housings.
Nope. I will not go over 5000k for these. Any higher then that and it causes eye fatigue and no color rendering. Not good for fast driving. Maybe if they came out with a U2 neutral. I can get T6 neutrals, but they where not in stock and cost a lot more. With this much light you are probably not going to notice a few hundred lumens.
Look Great BigToy! Circuit board assembly shop did a really nice job. They look almost as good as the prototype that I hand soldered (Kidding, They obviously look much better).
Here is the final design. Production will start in the morning. Finished units will be anodized black and be laser engraved on top. The light has a dull finish because I bead blasted it for a nice uniform finish. It will look good under the anodize.
