Someone please modify the link to neverb.
Some friendly advice to the folks at Neverbuying: the first rule of hole management is stop digging. Particularly if you're in violation of your hoster's anti-spam policy and depend on Paypal to do business. Looks like they at least removed the fake Verisign badge from their website. Perhaps they'll get the message and knock it off when their domain gets blacklisted...
If they use referrer to track who is linking to them and are not actually crawling this forum, then using a referrer hider like this should help, shouldn't it?
It should. And there are a few addons for Firefox and I believe Chrome as well, that allow you to configure on a site-by-site basis if you want to send a referer (sic) header at all. I use RefControl personally but it's also possible to turn them off altogether (if you're using Firefox, go to "about:config", type "referer" into the search field, right click "network.http.sendRefererHeader", select modify, enter "0" without the quotes, OK, CTRL+F4, enjoy) which may break some sites.
Looking forward to your observations with the XM-L.
Hi Hrvoje, did you try this with the XM-L drop-in yet? Im curious how this lens focuses it. Do you still like the light? Any down side to it?
so you got this from everbuying? cause all ive heard and seen is bad things about them.
did it come in ok?
Yes. All I can say, it is a wall of light, with a pretty good throw. I measured some 20000 lux at 1 m (black Trustfire 2400 mAh used). I used the pill from Manafont XM-L P60 3-mode drop in.
did it come in ok?
I get my flashlight from Dinodirect, but I ordered some other flashlights and accessories from Everbuying (all in all 4 orders in the last 6 months), and my experiences with them are positive. Just for an example, for me they are not better or worse than DX.
First post for me, but I've been into flashlights for many years and have a small collection.
I'm looking for a c8 clones and am currently considering one of the Suterfire C10 Q5 (about $17 @DX), Ultrafire C8 Q5 ($16.80 KD), Brinyte T6 C8 ($27 DX) and now the Trustfire TF-R2 ($28 Brandsdragon only place I could find it). All are grey in finsh, some with Q5 others with XM-L. My plan would be to upgrade the Q5's to XM-L if I chose to buy a Q5 clone. I have a monafont 3 mode XM-L on th way already and like the idea of being able to use it in the Trustfire host. The TF-R2 also looks like a beefy host so the heat transfer should be good. Not having any of the others I'm unsure of the cooling efficiency in comparison.
Any suggestions on the best clone body in the list?
thanks
Welcome Rolz.
Enjoy your time here.
Sorry, I don't have any of those so can't help.
Aloha and welcome to BLF Rolz!
thanks for the welcome guys
thanks
For exactly the same reason I bought this C8. (SZOBM ZY-C8). It beats my ultrafire C8 Q5 in both throw and spill. It had some very small scratches but else the quality feels good. It was $12.58 + $6.40 (ship).
And welcome Rolz and enjoy the forum. Your country delivered the future queen in my country.
Thanks again. I had a look at the SZOBM ZY-C8 and it looks a good unit Are you able to swap out the LED pill with a P60 as you can with the Trustfire TF-R2 (DBS V2 clone)? . I'll decide in the coming days what to do as I'm keen to get a torch for an XML that should be able to cope with the heat load on high better than a L2 or a skyray S-R5 body. I like th eidea of being able to use a P90 pill without haveing to mod th epill supplied with the flashlight
No, the P60 is a different and smaller construction and will not fit inside a C8. You can see pictures in this thread, the C8 is build like that and there is even a picture that compare with a P60.
I noticed some time ago Manafont listing an item TrustFire TE-R2. It looks almost identical to the TrustFire TF-R2. Does it appear to also be able to take P60 pills as the TF can?
This is the same flashlight. It is a typo.
Are any of these P60 pill compatible?
I have got this pills fits in head
Completely identical that that on photo
Possible use any pill from a P60 module?
