Yep, but still good throw. As I said earlier even after 1 hour of use the 4xAAA’s are still matching a P60 SMO 3A XM-L for throw and that P60 host had a TF3100 @ 3.99v. I have to say this lights ability with just AAA’s has surprised me.
IT’S ARRIVED!!! :bigsmile:
Initial impressions, I like it, it needs a set of o-rings, the threads lubing, I’ve wicked the thermal paste to the edge of the star, but I may see about machining an aluminium plug to build up the mass of the light engine.
As vfmaddict notes, its insanely bright on AAA’s, it has no right to be that impressive on such puny cells! 8)
My England (well Scotland to be totally accurate) sourced imr26650’s should arrive by Friday so I can play with it next week. The pwm is noticable, but I don’t find it overly irritating, although I’m thinking about an ld25 driver if I do make a plug for the heat sink. Over all though, now its arrived I’m very happy with it, nice heft, nice looking, jacket pocketable, would make a great gift for a none flashaholic who wants a bright light.
Good Call , VFMaddict 8) 8)
Not much to add to what’s already been said !
Fit & Finish is good
They are pretty darned impressive on AAA’s. :bigsmile: :bigsmile:
I didn’t notice PWM on them.
I hate the strobe, J) , but that’s not unusual for me.
Better o-rings & fujik on the star are about all they really need.
Copper slugs may be in their future , but for now I’m going to leave them as is !!
Thanks Guy’s ! Well worth the money…
I like mine so much I ordered 3 more. This has to be one of the best value for money torches out there right now. Guess what my non flashy friends are getting for Christmas/birthdays?
Is there any seller who ships to germany?
Mine finally arrived, but with an issue. The bezel was loose, and it just wouldn’t screw back into the head properly. I removed the o-ring that usually sits between the bezel and the lens and noticed that the thread ‘bites’ really late, and that the o-ring was preventing it from doing so. After removing the head from the body however, I was finally able to get the bezel screwed down with the o-ring in place, but only barely. The first time I screwed the head back on the bezel popped out again due the pressure the pill was putting on the reflector (which in turn was putting pressure on the lens, then the o-ring and finally the bezel of course). The second time I screwed the bezel down as tight as I possibly could, and was careful not the screw the head back on too tight. It seems to be holding up OK now.
What I really want to know is if anyone else can relate to any of this? If they are all pretty much the same I wont bother trying to get a replacement, but if they’re not I definitely will.
All in all this is a crappy quality torch (even ignoring my bezel issue) which was to be expected. But it’s not incredibly crappy. It redeems itself somewhat with it’s nice styling, decent output and battery options. But if I’d had a chance to sample a unit before purchase, I would have kept my money.
Size comparison with a couple of other well known lights:
If it looks like it’s on a little bit of a lean, it is. As mentioned earlier, I can’t screw the head all the way onto the body with the bezel screwed in, so it’s kinda just sitting like that right now. Have contacted the seller regarding a resolution.
Mines ok tbh, o rings would have made it fine as delivered, I still see it as a functional host but I am thinking of getting a few as gifts, a none flashaholic would be very impressed with it I feel.
Aside from the issue I’ve already described, mine came properly decked out with o-rings everywhere they should be, nicely lubed threads and even had thermal paste applied to the bottom of the star.
QC is clearly all over the place, in an almost amusing sort of way.
Would not be surprised to find out that “assemblers” we’re shown the “right way” to put them together and then were paid for each assembled light with no QC. Sounds like this could be a decent host if you get lucky or scrap Alu if you don’t.
So far, none have arrived doa, otherwise their much the same as Amy cheap Chinese light - lube, o-rings the odd poor threading job, I think its petty much par for the course.
Thing is though, the AAA output is pretty damm amazing, not many other lights can claim that.
Pardon my hyperbole, it’s a lazy habit. This light actually has me intrigued as a host if the threading problems are fairly uncommon. The other shortcomings sound correctable even for the budget minded. Could someone post some pics of the inside and what’s in there?
Edit- sorry, see the pics, skipped over a page by accident.
Yeah I should’ve had them send the o-rings they didn’t put on the tail when they sent my missing AAA carrier.
Used this light for like 10-15 minutes the other night and it actually got a little warm….
Noticed a outer ring on the already ringy beam that is huge. It is real thin but is quite a bit further out of the regular halo of light. If you hold the light horizontal to the ground it is nearly directly under the light on the ground. Hopefully someone will understand what I am saying as I have never seen this on any other light I own. Maybe a reflection off the outer bezel?
The seller is catching on. Price has been raised to 12.99 GBP ($20.29 US).
-Garry
I’m starting to become frustrated with this seller. I have tried several times now to explain the issue to them, but they don’t seem to be understanding me. I even made a video for them upon request. They are trying to tell me that I’m not screwing the head on properly, but that’s the problem! It’s not possible without the pressure popping the bezel out, which is partly because the bezel, when fully screwed in, only grips onto about one thread. The head can be fully screwed into the body if the bezel is loose, but that’s obviously a bit pointless, because it eventually falls out.
The only way to resolve this is to remove the oring that sits between the bezel and the lens, but then the lens rattles and there is no seal. Basically, it’s as if the reflector is too long, which I think is the actual problem.
Does anyone around here speak mandarin, or cantonese? I’d really appreciate it if someone who understands what I’m talking about and who speaks whatever language an ebay seller based in china is likely to speak could translate the substance of the problem I’ve described into a format that the seller can properly understand.
Finally the seller has agreed to send me a replacement head. It was a frustrating experience due to the language barrier, but in the end they’re doing the right thing by me I have to commend some of these China based eBay sellers who don’t require goods to be returned (because they know return postage costs are prohibitive) before they will offer a resolution. It all requires a little patience, but the essence of good customer service is there.
I’m probably going to end up gifting this torch to a friend who will run it on AAAs. I think he’ll like it.
I did some more testing on the light I received in a couple weeks ago. My first complaint when I received it was with a 26650 not fitting. The 4sevens one does not fit.
I got in a MNKE 26650 recently and tried it - this one fit in fine. A little snug, but ok.
So now that I had all the battery choices available I did some testing on it. I did discover that being a mildly driven light that it doesn’t matter if if you use a 26650 or 18650, if both are decent, they both provide enough amps to the driver to put out the same lumens. Now the AAA’s did put out slightly less power, but only about
A 15% percent loss.
So with the bigger batteries we did the testing. So we managed a 542 lumens at 30 sec. And we measured a throw of 23,700 at 1m. Basically not to powerful, but the bigger head helps in the lux numbers.
After that we did some field testing. Did real life throw measurements at various distances. This is what we got - 50yd = 10.7, 100yd = 2.4, 200yd = .6, 300yd = .2. So this light does have a real life throw of 300yds. Not too bad. If there was a decent way to up the amps some, this light would really be nice.
But considering the looks, and the 300yd throw, this light is well worth the money.
Thanks rdrfronty for your observations.
I just checked the shipping status on mine and it says "missent"! DUH!!! I probably could have had it in hand today! Should be soon as it seems the "missent" location isn't that far away.
-Garry
Thanks for the info rdrfronty.
I think that I might give mine away to someone and let them run it on AAA’s but not until I compare it to the HD2010 that I ordered this weekend.
