I don’t think I’ve read about anyone getting 5A from a SF 18650 on one of these - only with a good 26650. But, as Johnny Mac mentioned above - he got 3.5A with the TTF 18650s, as mentioned in his review. But Foy got 4+ with the same SF cells I have.
I think what we are experiencing is not just the DMM leads, which I expect to be part of the problem for me. Johnny and Foy test a LOT of lights, and we can’t blame any lower current results on cheap leads for them, I don’t think.
I think it’s li-ion cell variance, or worse, inconsistent East 092 driver draw.
Then again, the HD2010 is supposed to be direct drive on high. How would it’s draw be limited to anything under 5A in that case, unless the cells were to blame?
And thanks, Suncoaster! LOVE this torch, and it surely performs in the real world. But imagining an even brighter HD2010 with a good 26650 cell hitting 5A is a pretty fun as well. Congrats on yours as well.
I ordered a pair of TFF 26650s, just because there seems to be no visually noticeable difference OTF. But the Kongs appear to be some awesome cells that I will have to order at some point…
I use Panasonic NCR18650A cells. With the UF-980L (which is direct drive on high) I get up to 5.8A out of them. Before I made the custom leads for my DMM, I couldn’t get a reading much above 3A.
EDIT: Just wanted to mention that this reading is with a battery hot off the charger.
And what DMM do you have, cainn?
A good and cheap way to check DMMs is using Nanjg driver (with good cells). If you get 2.78-2.79A - your DMM is good at lease up to 3A :bigsmile:
I have a cheap “Digitor” DMM. In addition to checking it’s measurements against known values below 3A, I’ve also hooked it up in line while doing discharge tests with my hobby charger. At 3, 4 and 5A it matched what my hobby charger was reporting to within 10-20 mA.
What you need to keep in mind is when your making your leads low resistance is the fact that your tailcap may not be. The only way to get accurate results would be to measure it through the tailcap.
There seems to be a huge difference in what people are measuring on their HD2010's. Mine still pulls over 5 amps on both of my DMM's with a King Kong XSL. If I touch the lead against the battery as light as possible, I can get it down to around 4.70 and my leads aren't all that thick. (the ones it came with)
Foy, from all the reading I’ve done today, it seems I’ve confirmed (as well as I can from BLF forum posts) we all have the East 092 driver on the stock light. Lightmalls, Tmart, and Manafont are selling the same HD, or at least HDs with the same driver, regardless of the brand name on the body.
I charged my SolarForce V3 2600mAh cell to 4.27v and dropped it in the HD2010, and I’m getting 3.2A. I don’t have my TFF 26650s yet. I know your Kongs out perform those. But this SF V3 cell (I didn’t know before today because I didn’t have a DMM until today) is out performing my TFFs in terms of output.
I’m guessing either cell or driver variance at this point.
From memory I only got a maximum of around 3 amps from mine no matter what battery I used or DMM. I dont think with the driver in mine that if I hooked it up to the overhead wires used on the electric trains I would get a reading any higher.
Edit. Maximum I got was 2.7 amps. Just found it on Foys review.
Interesting. So how does direct drive factor into this? I was assuming the East 092 was direct drive on high… why wouldn’t it pull unrestricted? Or, maybe I don’t fully understand DD?
Yes, a clamp would be much more accurate. That's why all these tail cap readings should be used in relative terms, not absolute. Having said that, I'm quite comfortable with my measurements after getting nearly identical readings as E1320 on the same light. (his Fluke)
