Think it was some where in the time frame of 8/8/12-8/10/12. I think, I ordered it on the 10th and they shipped it this week. :heart_eyes:
I just noticed the HD2010 sells for $33 from Tmart now (from link in JohnnyMac's review).
-Garry
Hmmmm, its about $1.5 to the pound at the moment, must resist……
£20.80 for an hd2010……
I may have to break my abstinence come payday…
Finally got the AAA carrier. Very nice! Anybody stick one in a HD2010?
Wow nice shots 2X better then mine… But man I got gypt too. My lens well how shall I explain this. About 1/2 of the diameter of the lens
there’s these rainbowy effect. Maybe imperfect glass lens is causing this dimming effect 2/3s the way out. It’s not the outer bezel that’s causing it but I think it’s the lens. Also the last millimeters of the reflector there is 2 distinct BENDs! or cutoff that is CREATING some spot adnormalitities. Why would they ruin a prefectly good reflector by making this abrupt corners that bend back in? Shouldn’t a reflector be smooth and not have corners? What it feels like is a souped up Maglite. Instead of a solid spread then a fallout of XM-L lights. I have 3 of them (C8, 3T6 & J12).
I took the reflector off and wow… more uniform beam & has like 100+ degree good solid spread. I suggest other owners to try this if you have the same problem. It also has a tinge of yellow around the ends? Non-T6?
Anyways 26650 bearly fits. If you have any fat ones… they will be chipping each time they go in due to the screw interior of the tube. My skinny Tenergy 26650 was the slimmest, so it got in much better then the others (Flames/Ultrafire). Also the inside of the tube is bored out like a screw like the other parts or something they didn’t bother sanding it o something so I wish they did. Probably I can do it myself but bah that’s two negative ascepts I have for this already.
The grease or lube that came with my flashlight is a bit tangy, sort of like the organic type I get with my cheap 20 dollar ebay swords that leave your hand smelly after touching it.
And lastly my spring on my flashlight fell off it’s held by a tiny bit of solder. I was trying to err stretch the springs a bit for these other 26650 and it came off. Honestly this flashflight will probably kill TopofKing and I’ll never buy from him again.
In conclusion I think I need to buy a UCL lens or something to fix this issue or cut the reflector 2-5mm short to erase that cornering effect that is killing this light. I was amaze u guys say it’s the reflector? I’ll try to redo the solder and see what you guys did to fix this problem.
Oh God, here I go again!!, (and a 26650)
I thought about it, but was afraid of the extra voltage (the 4th cell adds). I'm not sure how the LED handles the extra voltage. I assume a direct-drive driver (like in this 4AAA light and the HD2010) does nothing to "buck" extra voltage. Besides, my HD2010 is now apparently dead.
-Garry
I was able to make a pill/heatsink to fill the gap under the star/led. This was my first attempt at making something like this. I made it out of spare/scrap aluminum belt idler from the machines I service at work.
On my 4th try I finally went to our main shop where we have a drill press, belt sander, press, torch and other tools at my dispossal. This was alot easier when you have the tools that you need for the job. I first squared the end of the roller on belt sander. Then put the roller in the end of a cordless drill so that I could use sandpaper to sand down the outter diameter to the desired size (22.6mm). Then cut it to the desired length (12mm). Where the idler rides on a shaft with bearings there was a hole in the middle (11mm). I filled the hole with random wire that we had laying around the shop and solder. Started heating it with the propane torch and started adding solder to fill in the gaps, worked like a charm. Then cut off the extra wire and put it back on the belt sander to make it flush again. Used a triangle file to cut some notches in the side for the wire from the driver to the led to slide through. Tried to press the pill/heatsink in and it was a no go. Finally i used sand paper in the gap in the torch body to get it to the right width. Was able to press it in then. VIOLA
Here is what I started with
Just after cutting
Sanded smooth
Wire crammed in along with solder - heating it up and adding solder
about to cut off the wire that has been added to the pill
wire cut off and sanded smooth, still needs filling up. Heated again and then filled it with solder
Filled and sanded smooth and notches cut into the sides
heatsink pressed in and smoothed out
Upclose white wall beam shot
I am satisfied with this mod and it now pulls the heat away from the led. The section of the light that was modded is probably double the weight it was. It gets warmer faster then it did before.
Sorry for the pics not beign great all I have is my Iphone 4s to take the pics
Please update on this guys?
some comparison photos:
ebay 26650/18650/4AAA light ~3.5A 35kcd
jetbeam bc40 24kcd
ebay big head, sky ray A0 clone ~3.5A 45kcd
marsfire w-068 ~3.5A 55kcd
ebay UF 3xU2 ~3.5A/led 28kcd
ok read a few posts…Seems a mixed deal and not shipping to Mauritius anyways
mouse out ebay 26650/4AAA, mouse over skyray A0 clone
Hey viffer750, which cells were you using in the 4AAA light? 26650's? At 3.5A I am sure you weren't running AAA's! And what light is "ebay UF 3xU2 ~3.5A/led 28kcd?
-Garry
that was with a sanyo 18650
the "UF 3xU2" light is a clone of tr-3t6, I won on ebay for $25
there are 3pcs u2 labeled x-ml-s in the head, I don’t know that they are real or not (probably, I measured 2500otf lumen at the light)
I made a "direct drive" driver with some current limiting resistors, and the desired current has been set to 3.5A/led
This cheap little (big) light has turned to be a great buy. I’m loving it, as it has replaced my HD2010, or at least filled the gap. It’s a budget player and we don’t want to ask too much from a cheapie (and we don’t want to run it on low), but it is a nice little thrower.
I agree wholeheartedly! Love mine! I have plans to get two more to give to friends.
-Garry
I gave one to a mate last Saturday for a birthday present. He has often been impressed with my lights, and seemed so with this one. Hope he likes it and it lasts the distance for him.
Mine arrived today, TEN days from china, fastest delivery I ever had from there!!, very nice finish and feel at first glance, have tried daylight shots with 26650/aaa, and the aaa definitely outshoots the bigger batt, maybe it’s because the big one has just got delivery voltage, still waiting for a charger for that one.
Was a bit disappointed with the brightness, but hey, budget after all
