What 18650s do you have, Jaffo?
Hey Sashi. So far, in the HD2010 Iāve only used my SolarForce V3s and my MF TFF 3000mAhs. These cells all charge consistently and seem to hold the charge well and deliver solid amps on my other lights. But I know I could have better cells. Suggestions?
(sorry, had to edit to add a zero. )
You meant Trustfire black/flame 3000 mAh, right?
AFAIK, and just my 2 cents, those cells are best bung for the buck. For a little bit more you can buy these Sanyo, similar discharge curve, with slightly less capacity but will offer higher voltage at the same current (i.e. better for DD lights). Best 18650 is Panasonic NCR18650B 3400mAh (Green). Protected and not IMR. If you want IMR, there are quite cheap and good alternatives, but they will be unprotected! Be careful to use these in DD light.
The bad part of all this is that I have my HD2010 on the way, and I have āoldā (but charged not more than 5 times) TF black/flame 2400 mAh :bigsmile: And these are quite worse than new TF 3000 and SolarForce V3 And you said with 26650 your HD is much brighter. Darn, I was thinking that 18650 will be enough for me :bigsmile: Looks like Iāll need to buy one 26650
Yeah, those TFFs.
Yeah, I knew I had decent 18650s, and was expecting higher amps in my HD according to Foyās review, but there is obviously either variation in the East drivers, or maybe my DMM leads are still sub-par. But it isnāt just me reporting less currentā¦
As Foy stated above, 3.5A will be as much as we need through the HD2010, but, as Iāve discovered, it may take a decent 26650 cell to get yours there. Iām fine with that, because now I have around 4500mAh capacity to play with.
Not sure DD is the best answer in this caseā¦ 5A+ is impressive, but if it really doesnāt get you any practical increase in performance, whatās the point? I wonāt have to swap drivers with mine, I donāt thinkā¦
Sure, no need +5A if the XM-L sweet spot is 4A But from 2.5A to 4Aā¦ there is still a noticeable difference.
Oh, much agreed. Just went outside to confirm. Yes, the 26650 is brighter, but not by as much as I thought initially. But maybe the run times are worth itā¦ Looking forward to getting that second HD, hoping itās a winner over this winner.
Andā¦ a Kong or twoā¦
OK, received my HD2010 this morning
Lol, 1.4A with my 3,8V TF flame 2400 mAh :bigsmile: Chargingā¦
ok, ive had my hd2010 for a lil whiles now, and reading this thread is making me itch to buy a 26650. so i concluded that i want some king kongs. but i notice they make them in icr and inrās. which one do i get? can someone recommend me a decent charger that charges two at a time also thanks!
Now $30.84 at Tmart when using 8% off coupon code: TMPRICE
Glad you got yours SashiX, I ordered the light at the same time you ordered yours!
SashiX, whatās your verdict?
darnit. i just ordered another one last night! and they shipped out out this afternoonā¦.grrrreeat. thanks for the coupon though
Hmm, could this (HML and 4 or 5A) fit in HD2010? Diameter seems to be OK, but the height? Should be easier to install than those 8x7135 chip drivers.
I have looked at this driver myself the last couple of days but do I really need it. It has memory as well which is not stated on the web site.
Here are a couple of pictures with an 8 x 7135 in a stock pill that I have done with little modification. I know I have a lathe but I have seen some of you guys do fantastic work with dremels that could do this with little effort.
Nice work. Did you just cut the recess a little deeper for the new driver and leave the ring stock? I may have to dust off the lathe and see what I can do. I have a bunch of 3/4ā alum bar stock left over from an old project but this pill is bigger. Hope I donāt screw it up.
I think the HD2010 is a great light except for the crap driver. Mine has HI, weird high speed flash. LOW, stupid strobe and even stupider OSO ( not SOS) I am aslo going to swap out the LED because the stock one is way too blue.
Larry
I just machined the step down deep enough to screw the retaining ring on and everything else is stock. The driver seems to earth fine through the small lip on the back ok and it may be wishful thinking but the retaining ring may cool the chips on the driver slightly.
Will post an overview this night
