Test / Review: EnerPower+ 18650 2250mAh (Blue)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 4 hours ago
DSC_0330
Official specifications:
  • Nominal Voltage: 3.6V
  • Capacity: 2250mAh
  • Minimum Capacity: 2150mAh
  • Standard charging current: 450 mA for 5.5 hours to 4.2 V / 0.2 C
  • Maximum charge current 0.5 C/1200 mA
  • Protection: 7A
  • Deep discharge protection: at 3V
  • Nickel base plate for added durability
  • Diameter: 18.5 mm + / - 0.01
  • Length: 67.8 mm + / - 0.01
  • Weight: 46g
EnerPower+%2018650%202250mAh%20(Blue)-info
This is a high current battery with protection.
DSC_0329
DSC_0331 DSC_0332
DSC_0333
DSC_0334
DSC_0335
EnerPower+%2018650%202250mAh%20(Blue)-Capacity
The battery has no problem delivering 7A, but the protection does reduce the output voltage, compared to unprotected batteries.
EnerPower+%2018650%202250mAh%20(Blue)-CapacityTimeHours
EnerPower+%2018650%202250mAh%20(Blue)-Energy
EnerPower+%2018650%202250mAh%20(Blue)-PowerLoadTime
EnerPower+%2018650%202250mAh%20(Blue)-TripCurrent
EnerPower+%2018650%202250mAh%20(Blue)-Charge
Conclusion
Adding protection to the cell, makes it easier and safer to use it, but performance is lower than unprotected cells.
The battery is a very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Edited by: sb56637 on 08/26/2014 - 17:45
Chicago X
Chicago X's picture
Last seen: 8 years 6 months ago
Thanks for the review.  These are the first of the CGR18650CH that I've seen with protection circuit.
Do you have any data regarding low-voltage cutoff ? Thanks.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
HKJ
HKJ's picture
No, but it is probably between 2 and 2.5 volt.
sb56637
sb56637's picture
Last seen: 4 hours 53 min ago
Thanks so much! Frontpage’d and Sticky’d.
