Sorry, C-channel, far too an important question to let go unanswered! Absolutely do NOT mix different battery makes or types. All four batteries need to be the same type and model from the same maker and preferably the same batch if you can. They must be balanced and matched or else you run the risk of bad things happening.
I have used a silicone based spray lubricant applied to the driver board with a cotton bud. Its in a can like WD40, but is meant for using on spark plug leads and electrical contacts, and it seems to work well on flashlights too.
Thanks Johnny Mac. appreciate your answer… I was hoping that it could be used as I read that the SkyRay King operates the batteries in Parallel. Think it is time to make some new purchases…
I may go for it. Does anyone have internal pic of the Skyray and the other clones to see how the leds sit and the build quality. Thiws my be just the same light internally. Manafont does not sell any poor quality light apart from the Ultrafire x1
I got a set from KD when they have the offer and I believe I got the MIMIC set.
The set that i got was exactly the same as what manafont is selling as mimic copy.
1. Sky Ray logo different from original and is smaller.
2. Lanyard is different from original and is dark brown with lower quality
3. Driver board is different with rough edges.
4. Spring end is different. rattling sound even with 4 battery inserted and screwed tight.
I do not have an original copy to compare the performance…
All these photos of original are compared with the reviews posted in BLF.
If you read through the comments you’d see that no one has both the mimic and the original SR king. We can’t definitively say which one is better until someone can compare one with the other directly.
