Hi guys just posting this to get a lil input i want to see what u guys think i should put in this mini bad boy ? i have a 3” aluminum slug coming for it with a large st-90 reflector and A ASPHEIC LENS?
im going to have a rear McClicky installed so im not sure if i want to go the aspheric way YET
The handle is from a mag and the part connected to the mag handle is the mini version of the large SHOWER HEAD that is the top section……
Nice set up nitro,I would go aspheric especially with the larger die leds,makes a nice big hotspot.I also would check the McClicky and the amps it can handle,no so sure it can do 10+amps.What driver are you using or will you go DD?
Oh,I took your description of the ST 90 reflector out of context,I thought you were using a SST-90.I think the sbt-90 is an awesome led and costs alot,but would be ideal in an aspheric.XML-u3 wouldn’t be a bad second choice or even SST-90.I wanted to do something like this with aspheric and sbt-90,but I have too many irons in the fire right now.
man… you had to show me that switch too huh. i hope i get back to work soon. been in a mag modding mood. whered you get the black head? guessing the “other” place
No nothing special made, I just had 2 flashlights and made them fit with each other with little jb weld, and i cutted the threaded section off one body and got it to work with the mag D body so it can screw in with each other
