Yeah, I’d be interested in picking one up only if a U3 option was available and if the amp draw is fairly high.
Does it come with a carrying pouch?
Nice deal, count me in for option 2 shipped via China Mail and with a EU plug.
My suggestion for the name would be A8 BLF Edition.
+1 on the U3 option and the NANJG 105C driver.
I’m in for one. Option 2.
Any chance of an OP reflector?
This is assuming we all survive 12/21/12.
+100
A good point!
If available, I would take with OP, too.
Over 1KHz PWM would also be highly valued.
I’m in for option 2.
I like “A8 BLF Edition”
High(3A), med(1A), low(350mA), moonlight(100mA)
Short memory, starts on low(momentary off to change modes, longer off comes back on in low)
T6 3C NW
Higher pwm
It’s a big light that’s primary reason for existence is to throw out a lot of light. It should start in high.
^^^ This.
I have multiple pocket size AAA or AA lights for moonlight or firefly mode. Don't need this big bruiser doing it too...
I don’t know, moon light has its uses. I’m happy if it has no damm flashy modes though.
Sorry for the confusion. I don't mind the Low, just want it to start on High, which was ouchyfoot's point. I was agreeing with him that the primary use of a big light like this is high output, so modes should start on High.
Fair comment, I’m seeing this as a house/camping light, the moonlight would be ideal for checking on the kids, in that instance, starting low and building up would be better - little point switching down to low if I’ve already blasted 800 lumens into the area….
As I’ve said earlier though, I don’t mind which way it goes, I can adapt myself or maybe build another edc that suits me.
I do have a plan for a trustfire t2, three nichea 219’s and a kd 3a nanjg driver, I may order 5 that start moonlight and build up to 3a in one mode group and start at 3a and work down to moonlight in the next group. Then I have either option on other mods. 8)
Edit, perhaps Rey’s having this kind of driver fitted, in which case, if they were ordered as I specified above, people could change the mode run to either way, you’d only need an iron and a solder sucker or some braid to remove the solder bridge.
Check on the kids with a zebralight. It’s tiny and will run forever on lo/moonlight with one AA.
Yep, but that means stretching to a zebralight, to give you an idea, my most pricey light is my ancient incan 3d Maglite, otherwise most of my lights are sub $30, I truly am budget minded.
Mods may run to more if I tot up the bits, but part of the value to me in those is the satisfaction of messing about building something myself.
hi,
i did not hear that it will cause a duty and tax by DHL.
if i declare the value at only 10-20$.
Best Regards
Rey
Hey WWEFANS
Have you decided on a name yet? There’s been a lot of different suggestions thus far. Perhaps we need to poll it.
Just put BLF Edition on it.
