New bunch of XM-L today at DX (14 new lights!)
22 posts / 0 new
fran82
Last seen: 12 months 16 hours ago
14 new XM-L lights at DX today!
Some P60, some old aurora bodies.... interesting... but... the 2 mode ones... Are done with resistor at tailcap? no electronics, like old P7 aurora 2 mode....
504B black XM-L 1 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led...
504B black XM-L 5 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-wh...
504B silver XM-L 1 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led...
504B silver XM-L 5 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-wh...
UltraFire TH-T60 5 mode http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-5-mode-1200-...
UltraFire TH-T60 2 mode http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-2-mode-1000-...
UltraFire KH-T60 5 mode http://www.dealextreme.com/p/ultrafire-kh-t60-ha-ii-xm-lt60-5-mode-1200-...
UltraFire KH-T60 2 mode http://www.dealextreme.com/p/ultrafire-kh-t60-ha-ii-xm-lt60-2-mode-1000-...
UltraFire NH-T60 5 mode http://www.dealextreme.com/p/ultrafire-nh-t60-ha-ii-xm-lt60-5-mode-1200-...
UltraFire NH-T60 2 mode http://www.dealextreme.com/p/ultrafire-nh-t60-ha-ii-xm-lt60-2-mode-1000-...
UltraFire NF-T60 5 mode http://www.dealextreme.com/p/ultrafire-nf-t60-ha-ii-xm-lt60-5-mode-1200-...
UltraFire KF-T60 5 mode http://www.dealextreme.com/p/ultrafire-kf-t60-ha-ii-xm-lt60-5-mode-1200-...
UltraFire KF-T60 2 mode http://www.dealextreme.com/p/ultrafire-kf-t60-ha-ii-xm-lt60-2-mode-1000-...
1000-1200 lumens. Overrated......
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Edited by: fran82 on 03/17/2011 - 16:13
jb1
Last seen: 44 min 11 sec ago
Thanks for the links.....gotta go check them out.
Wait, the lumens are overrated?   LOL
Vectrex
Vectrex's picture
Last seen: 10 months 2 weeks ago
Forget the lights ... I want that battery...lol
Don
Don's picture
Last seen: 1 year 1 month ago
Smile
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
jb1
I know DX lumens claim is all over the board, but why are some XM-L lights rated at 1,200 lumens, 1,000 lumens and the ones on here @ 510 lumens? Do some have better drivers? They're all listed as T6 so what gives?
mizjif
mizjif's picture
Last seen: 1 day 29 min ago
The ones stating the 510 lumens also stated they are driven at a regulated 1400 ma (1.4a) while the 1200 lumen claims are driven at 3000 ma (3a)
edc
edc's picture
Last seen: 6 years 1 month ago
Dx shXt me. My order was "packaging" for weeks and then I ask to cancel it - so they post it. I'd rather pay a few dollars more at KD and manafont etc.
sorry not  really off topic as I ordered my xml light after seeing a "whats new at dx thread". Still waiting.....Frown
http://i1193.photobucket.com/albums
fran82
fishinfool
fishinfool's picture
Last seen: 2 years 4 months ago
fran82 wrote:
More XML!
2x18650 XML light
http://www.dealextreme.com/p/beamtech-t6-cree-xm-lt6-5-mode-850-lumen-wh...
Big XML dropin (posibly for mag mods)
http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-900-lumen-smooth-a...
Both links won't work for me for some reason in both IE and Firefox.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
fran82
They work check again
Don
Don's picture
I think this is aimed at the TR-1200/WF-500 type of lights rather than Maglites - it seems a little on the large side for a Mag dropin. The Mag head is a little under 52mm inside diameter. I think. The Mag replacement lenses are 52mm in diameter and are larger than the inside diameter of the Mag head. If it will fit in a Mag head you'd either need to use a 5 or 6D since it gives a minimum voltage of 5.8V. It would probably run for a very long time on full output in a 6D but that is hardly a pocket light.
But it is quite possible I am wrong - it wouldn't be the first time.
Volk
Volk's picture
Last seen: 9 months 5 days ago
Don: I think you're absolutely right about the dropin being for UltraFire WF-500. If you look closely you can see the threads at the end of the reflector which is the way you install the reflector in the WF-500. And the contact springs looks to fit the WF-500 to.
To bad about the flashing modes though...
fishinfool
They work just fine now.  Thanks fran.
jamesearljonesi...
jamesearljonesisascab's picture
Last seen: 9 hours 2 min ago
i got a 4d mag led that could use an update. did search and came up with this not so budget dropin http://macscustoms.com/MagLiteDropIn.aspx
03/04/16
8 lives left
Match
Match's picture
Last seen: 5 years 7 months ago
4D mag?  There are a lot of options for that one as long as you don't mind a bit of dyi. A pretty simple one would be the 5xR2 drop-in from dealextreme for about $33
fran82
New XML and... a new.... new... what????
UniqueFire M9 XML 1 mode http://www.dealextreme.com/p/uniquefire-m9-cree-xm-l-1-mode-700-lumen-wh...
UniqueFire M9 XML 3 mode http://www.dealextreme.com/p/uniquefire-m9-cree-xm-l-3-mode-750-lumen-wh...
Another TrustFire TR1200? 35 dolares? cheaper? what differences from the old one??¿?¿?¿
http://www.dealextreme.com/p/trustfire-tr-1200-cree-q5-wc-5-mode-1200-lu...
Foy
Foy's picture
Last seen: 6 years 7 months ago
Those Ultrafire 504 XM-Ls for $20 seems like an outstanding deal.  I couldn't build one for that; the stainless bezel ring alone is $2.50 at Solarforce and figure $10 for the host.  If Manafont came on here with a cash-back campaign that netted an XM-L drop-in for $7.50, think there might be a stampede?  These may or may not be the quality of a Solarforce but even so . . . am I talking myself into this or just pointing out the obvious?
Very good find, either way.
herewegoagainFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
Budgeteer
Budgeteer's picture
Last seen: 8 years 2 months ago
What we lack is good flashlight bodies (P60 and others) for cheap! At 5-6usd i would instantly get a few 504B or similars. But no1 i think is interested in seeling those with just 20% markup...
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
fran82
Yeah TrustFire X8 (complete kit) at DX
http://www.dealextreme.com/p/trustfire-x8-xm-lt60-5-mode-1000-lumen-memo...
And another not XML, but SST 50, TrustFire X7, another complete kit
http://www.dealextreme.com/p/trustfire-x7-sst-50-5-mode-1300-lumen-memor...
Oxy Moron
Oxy Moron's picture
Last seen: 3 years 5 months ago
I know it's not going to happen but I wish they'd just knock it off with the box sets. The box itself makes shipping uneconomical for most HK-based retailers, which in turn unnecessarily increases the price. The batteries are almost always unprotected and/or of questionable quality and the chargers tend to not exactly inspire confidence. *steps off soap box, stops preaching to the choir and grabs another slice of cold pizza* Wink
jb1
I'm with you on that one Oxy Moron, but I'd bet that Average Joe does like the box set and it's a way for them to increase their profit margin.
Kokopelli
Kokopelli's picture
Last seen: 2 years 7 months ago
I sometimes look for lights with box sets if I am buying them for the friends or relatives. It may sometimes make it economical too, as I tend to buy Black-Flame Trustfires as 18650 and a more decent charger instead. Ok, that charger thing sounded like I'm handling a bomb. Maybe just protected cells and a crappy charger I could get.
