from what I can tell my v31a is regulated…how long does it run in regulation? no clue…but as the battery drains and voltage drops the tailcap readings go up…clear indication it’s regulated…
As far as a total breakdown (found out by accident). the head does break down further, it is hard to tell but where the smooth part ends is where it is threaded together and allows you to remove the reflector assembly from the emitter.
These are very fine threads so would not recommend dis assembly often.
As far as I can tell the body does not come apart near the switch end.
Thanks for the tip mkett. Good to know.
Been using the V31A as my office coat EDC. The initial ‘new light glow’ has faded a little, but still digging it very much.
Further to my notes above…. The switch on my V11A is a tad wobbly when tailstanding, but it works. The V31A stands completely flat and more solidly. It is a minor mm or two difference between the two.
Switch actuation on my 31 feels a little tighter and more precise as well. The 11 has a teeny tiny amount of slop to it. I think it may just be the rubber switch cover and not the switch itself. It is very minor difference between my two models, probably normal manufacturing variation.
Of course…… I can’t access the switch end of the body to dick around with it! grrrrrr Dammit.
I like lego lights because they provide extra redundancy and backup.
Thanks for the heads-up how2. I had not seen those lights you linked before. They look fairly promising, but I agree the pricing is on the high side. I am not familiar with Marsfire, but if they are similar quality to the other **fire brands they should be sold for less. Closer to $15, as you said.
By comparison, the Crelants in the $30 range have a much higher quality feel to them. A better value for the money for sure.
Haterade the Crelant V11A, V21A and V31A has lego head and bodies. You should all of them but the marsfire has a slight advantage in terms of cell types.
Another brand which will have lego is the EXPLORER E82, EXPLORER E84 and EXPLORER E83 just like Crelant and looks worth the money.
May pick up a v21a eventually, but not really big on multi-cell lights in general.
Should also mention I completely detest and loathe flashy modes. I avoid them like herpes, even if it means paying a little more. This is part of what drove me to the Crelants in the first place.
The Explorer series you linked [one of them does not work] with the ring UI should make it so I never have to hit SOS mode. That is huge. Could seal the deal.
Again, I am not familiar with the Explorer brand. Is the quality really on par with the price (considering price I paid for the Crelant from US sources)? If they were closer to $20 it would really be tempting.
Fixed
cheers mate
Received mine a few days ago (V11A). For the price I got it, just under $30, I'm quite happy with it, however I am less than pleased with performance on nihm batteries. I realize they are not the best, but I got 12 Duracell 1600mAh batteries, and tested with those.
Light barely seemed to want to work at all with them. I have yet to test it out with a regular alkaline AA, but with a protected 14500 it does work very well.
As others have noted, mine also tail stands, but the tail switch protrudes just a bit, making it unstable.
I would love to find a better AA/14500 option, currently also have the Balder HD1 which is also AA/14500.
Check your voltage on those NiMh and also try some lithium primaries. That doesn’t sound quite right.
My V11A puts out about 1/3 to 1/2 the output on NiMh (eneloop XX) than 14500 IMR, but it definitely works OK… If I had to guess, maybe about 150-200 lumen? Seems about right to me considering the voltage. I did not even try standard alkies, but energizer L91 lithiums looked about the same as eneloops to my eye.
You said yours ‘barely seemed to want to work at all with them’ and that does not sound right. XM-L needs high current to really perform, but output should be pretty much proportional to voltage (about 1/3 - 1/2).
Might want to stick to XP-G emitters if you plan to use low voltage cells often. They seem better suited to AAs than XM-Ls are. Unless you go 2xAA that is.
Have you considered the Jetbeam BA10?
I figured I'd post an update, since I've been using the this crelant quite a bit.
The light has grown on me. In fact it has grown on me a lot.
While it's big for a 14500/AA, that also means it can handle a longer run on high. Which was very useful last friday when my office power went out.
I'm still looking for either a better 14500/AA but for the time being, the crelant is getting the job done.
That’s a good point. The size does help with heat.
Is that the xp-g2 Archer 1A kreisler?
I have been eyeing that one too. The strobe might drive me away though… Wish thrunite just updated the emitter and kept the Neutron AI, switch, & modes! I guess the new setup will permit true momentary on, but I don’t really care for that. Hope they at least improved the clip on the Archer 1A.
Might be kinda tricky to compare xm-l crelant V11A to xp-g2 thrunite Archer 1A. The emitters put out similar lumens [up to 1.5A anyways…], but have totally different throw/flood characteristics. Different uses? The thrunite is a little smaller in size, if that matters.
The Crelant is pretty. Almost too much so.
Thrunites are nice and simple and purposeful.
Each is visually appealing, in their own way.
What is the difference between quark tactical and archer UI? You said archer UI is not so good - why?
Neutron UI is perfect IMO. I only wish the beacon mode with head loose did not exist.
hmm so how does the quark tac do momentary? I must be missing something.
I’m curious to see how you like the archer when you get it. I might just spring for one myself as I am kind of a thrunite fanboy.
Oh yeah, that’s right. Forgot the prog bit. For all intents & purposes its a programmable two mode.
Good old nutnfancy
I bought a used V11A for $20 and I was drawn to the body design. The light isn’t very bright using AA, using a 14500 is a different story, very good output. I’m not crazy about the V11A’s UI. It has memory and you can’t change modes while the light is on, you can only change modes while the light is off by soft pressing and then fully pressing on the mode you like to use. It comes with extra o-rings but from what I observe the body can only be disassembled from the head. Looking down the tube I don’t see anywhere to place tweezers to remove the tailcap. I haven’t tried removing the bezel but it appears easy to do.
Where did you guys get the Thrunite 1A?
It looks like a nice neat light, but I'm having a bit of sticker shock from the $60 price tag... the crelant I got for $30, the balder for a little less even.
