(closed,all sold out) Give me your money: 2nd BLF Light, TrustFire A8
Worst case scenario, a kd 3a moon low driver is what? $5 if that? I’m not worried about the charger, have a tr-006 that seems to work well and king Kong’s and keygos cells to feed it, I just thought Rey said the drivers were two dollars a pop when ordered with the light (just checked, $2.5) so a few drivers in with the pack is a cheap way of refreshing some cheap xm-l lights to me.
I’m satisfied, I’ll be happy when Rey has took my money and the package is on the way. 8)
_the_ Thanks for the update , looks like its a go btw, no one came up with BLFFire [quote=_the_]
Finally got the light. It's gorgeous! More than worth the long wait.
I don't know where to start, but I'll try..
The light came very well packed, as usual when dealing with Rey. Thanks!
Here's the retail package:
..which contains: The light itself, a holster, TR-005 charger, and one TF26650 "5000mAh" protected cell:
The light says: "TrustFire A8 - BLF Edition": (Please ignore the dust spots)
The charger can charge one cell at a time, anything from 16340 to 26650:
It says "1500mA", maybe so in the beginning, but the included 26650 at 3.78V charged at 400-500mA.
The modes are High->Med->Low->LowLow, with perfectly working memory (more than 2s off -> same mode, every time)
Brightness is about 650, 260, 16 & 2 lumens OTF (Tailcap currents 3.85, 1.04, 0.04 & 0.007A with Kingkong ICR at 3.95V and 3.29, 0.90, 0.04 & 0.006 with the included TF cell at 3.92V)
Duty cycles were 100, 30, 2 & 0.3%
Estimated runtimes with a 4000mAh cell are about 1h, 4h, 100h, and 571h
I wouldn't call the lowest mode "firefly" or "moon", but it's very usable "low low" with theoretical runtime of over 23days!
Here's the same in photos (1/100s, F/5, ISO80, WB:Daylight)
The PWM is very high and totally unnoticeable at 2kHz.
What more can I say..
All systems green. Go ahead! Good job Rey & TF!
[/quote]
benckie gave the charger a good review (although he doesn't mention testing charge current).
I was really hoping for a good charger! Would like to hear _the_ review it more thoroughly, otherwise I might have just order the bare light. How about the TF cell - is it legit?
-Garry
_the_ can you get better tail-cap reading on a fully charged battery 18650 and 26650. And batterries with voltage below 4v please.
How many batteries do you have?
The more you have the better readings you can get with different batteries.
I just re-tested the light. The output measured by ceiling bounce is about 44% of Rook's output, which should be around 1450 OTF (according to JohnnyMac's IS test) => about 650 lumens OTF
On the other hand, the output is on par with my XinTD C8 NW v3 driven at 2.8A.
Tailcap currents with different cells were from 2.5A (unprotected TF flame 18650) to 3.85A (XTAR 18700 2600mAh). Most probably the light is DD on high(??)
About the charger, I don't know what's wrong. I re-tested to charge the included TF26650 and the charge current was now only 300mA. Maybe the current goes down when the cell starts to get full? I need to investigate this further some day..
I need to sleep now. CU tomorrow..
Sleep! You don't need no stinkin' sleep! You've got fellow flashaholics waiting for more information! (Just kidding.)
-Garry
It's already 00:13 and I have to wake up at 06:30.. Sorry.
But please go on with this discussion and try to figure out what to say to Rey. Should we go forward with this of wait for possible fixes? (I like the light very much! Even if it would be DD on high.)
Does anyone else have TR-005? Can you confirm my findings? Or did I just get a lemon?
Ok, from someone that has had this light and charger combo: I think 650 lumens on the stock light is a little light, but I don't have an integrating sphere to dispute that. I get over 1-1/2 hours run time on high. The charger is the fastest one I have and it will charge the TF in 1/2 the time it takes on other chargers, so I have a hard time believing it's only charging at ~500mA.
Perhaps the current drops as cell voltage increases to prevent over charging?
Heck, why worry, for the price on the charger and cell, its still a good kit, and looks good in its display box.
I will not like to have a light that either
1) stuffs 3.8A in an XML, it is hardly noticable brighter than with 2.8A, it is hopelessly inefficient (also in the lower modes because they are just created by the PWM) and ruins the led in time.
2) or else just looses 1A (more than 3 extra watts!) somewhere in the form of heat (on top of the normal losses).
The charger I received did not work at all. From memory on pulling it apart the positive terminal had broken of the circuit board and had to be soldered back on. I no longer have it as it was bought as a gift. The charger should ramp down as the cell gets a higher voltage in it.
Can Rey not change the driver?
I was hoping for 2.8Amps on high on any good battery, I have too many DD lights.
I'm in two minds weather to get this or not. Would have bought 2.
Why just 2.8A? Why not 3.2 or so…
Of course the current goes down with full battery this is how cc/cv works. you have to measure the current on the beginning,it should be constant till the voltage rises…
But I don’t care about the charger, I want the flashlight only :bigsmile:
@–the— how did you test the tailcapcurrent current? Do you have thick measuring wires?
3.85A sounds strange to me. I called TF engineer.
he told me 2.6 2.8A is the highest he can do.
i will check again.
BTY, i will update some information on the #1 post with today.
Nothing to worry about the charger, it's obviously on CV mode during the last charging stage (Constant Voltage, and steadily dropping current).
What seems not quite right is the 73% efficient driver (assuming 2.8A output / 3.8A input). Too much lost there considering it's a single cell config with closely matching battery/emitter Vf.
If direct-driven, LED would actually get the same current at 3.8A and produce around 800+ lumens on start. This is apparently not the case. So this may not be DD, but very inefficient driver?
=the=, is it possible for a close-up macro picture of the driver?
EDIT: I forgot that this is NW, so it is harder to tell based on light output. So, another thing, can you measure tailcap current AND LED current from fully charged battery?
money sent(1 neutral and 1 cool white A8, one kit, one straight torch) from Rey and some additional batteries. Can’t wait for these to get here! J) These I think will also be my last lights of the year since I’m up to 6 outstanding torch orders coming in… now if only the weather here wasn’t so cold so I could actually take a little drive out west with them and do some comparative shots.
i would like to add another light to my collection… hopefully getting it by christmas
i want option 2
  • 1 driver via DHL for me ( does the light comes with holster? if not… it should, after all… it’s BLF edition)
    :slight_smile:
That was my initial thought. Anyways, 500mA @3.8V did sound quite little to me.
I have to try with a fully depleted 26650..
By shorting the body and negative terminal with my DMM (in 10A measuring mode). The leads are thick enough. (Otherwise I would get too low results..)
Sure. But I'm at work at the moment, so you have to wait until the evening.
