“Up to 20” is what Cree says. I believe I saw someone say the 20 takes into account the variability in bins where you could have one LED at the bottom of the bin and another in the same bin, but at the top of its range. That gives you 7, but that’s true of any two LED’s in the same bin. On CPF, Selfbuilt compared Foursevens XP-G lights against the newer XP-G2 lights where 20 is also thrown out and he said he wasn’t getting that much.
The Cree datasheet for the XM-L2 goes up to a U2 bin, but I don’t know if that will really be available. Because the LED’s are binned differently, what do you compare against? The two top bins: XM-L U3 vs. XM-L2 U2? Right now it seems like T6 and U2 are the most available XM-L bins. Once we know real-world bins for the XM-L2 and people start taking measurements, it will be easier to do comparisons.
So, these can be ordered today from DigiKey or Mouser. Voltage is the same, mounting is the same, size is the same... Hhhmm - so, just order them and try mounting on a star? Not sure if the DigiKey U2 one can be equated to 1A/1B/1C, etc. Can that be determined from the CREE part # or that now obsolete for XM-L2's?
Am I wrong here, is there something I'm missing? Not sure if anyone said the mounting dims are the same. From the diagram above, looks like the pads are the same layout, not sure of the dimensions...
Update: Crap, not in stock anywhere. Mouser has a min order of 151 or 250, something like that. Looks like DigiKey min order is 250 looks like -- that sucks...
Yes! I see that now. So, basically you can get an XM-L2 T6 rated at the same brightness as an XML U3. Not sure how good this is, but looks like the T6 is a neutral color. Hhhmm. Are you ordering any? Anyone else? Will these really work on a stock XML star? I know the voltage is good, I think the LED (itself) size is good, not sure of the mounting dimensions.
20% is in reality still only 5% to the eye ..it won't wow you ..
This is another conspiracy by Cree to make you buy another purple cw emitter.
seems to work
My opinion of the xpg2 nw 4c is it's very very good compared to a nichia it's very close to the same cri maybe a bit pinker than the nchia but also much brighter ..2thumbs up on the xpg2 nw....4c
Well, I don't think a 5000K tint will be purple... We are talking T6 neutral - meaning yellow/green. Tint snobs say purple, lumens snobs say yellow/green .
It's an XML T6 3C on steroids - increasing muscle mass by 20% ain't easy, getting 20% more horsepower (ex: 300 to 360 hp) in your car is gonna cost you some major bucks and a lot of work... Now if only I could lose 20% of my body weight... Ex: 220 lbs down to 176 lbs.
Im glad cnqualitygoods had to cancel my order for the 10 U3’s I ordered. The only problem is that I have several flashlights taken apart and awaiting their new XM-L’s. I bet we wait a good 3-6 months before the “2” becomes available outside of Cutter.
This sounds great. So can you tell me, does this mean the XML-2 has a higher output and also will use more power- in other words have a little less run time but just more output, or has the efficiency stayed the same or better??
Feel like holding off on new lights until these start showing up!
