Mine has the rattle issue, the bezel has no problem, it has an even gap.
I have it from Illumination Supply.
Craig said it may be a loose screw inside.
What is the proper tool to unscrew the bezel?
I have tried shoe rubber, not worked for me.
I took apart a few EA4s which have the rattling problem.
The culprit is the white delrin ring
I’m not entirely sure as to the purpose of the ring (other than to fill up the empty space in the light, but some are ever so slightly thinner than others, and cause the rattle. This does not change the reliability of the light at all.
yes, it’s right below the reflector. However, due to the size of the reflector keeping the reflector in place
and the centering ring around the LED, this seems like a bit of overengineering on Nitecore’s part.
which bit them in the backside, lol.
I know exactly what you mean, when I tracked my PD32UE today and saw that it was coming I kept watching the clock waiting to hear the sound of the mailman… It’s always nice when you have orders coming it gives you something to look forward to!!
Thanks you all for the findings about the rattle issue,
I do not mind to open it, because it is clear that is nothing to do with performance and may not cause a problem in future.
Rick, it still has a slight rattle, but I'm ok with that. The Bezel was my main issue. I can always fix the rattle. I know you straightened your bezel, but I'm extremely anal. Just knowing that it was cross threaded is enough to ruin the experience for me. I'm weird, what can I say?
