I will take a risk and call it UF-T50 since I have had one failed H51 but 0 failed UF´s so far 8)
If I should foresee something, I would say that ZL´s driver gives up.
Of course, the idea is to push and test these, not doom them to the pit of never ending darkness. Before this thread even went up, mkett39 suggested running them over on a surface that has some give Here’s an example of that with a steamroller: http://youtu.be/km_rodQCs2M?t=1m17s Trust us :Evil:
Tests performed so far: bury in snowbank overnight, leave lit underwater in basement sump for one hour, wash with laundry in washing machine twice, on heavy cycle both times, dry in dryer for 40 minutes, bake in oven at 200 degrees F for one hour. Both lights survived but one clearly did better than the other — so far, that is! But which one?
Remaining tests: freeze overnight (lit) in blocks of ice, defrost and boil with eggs for breakfast. Then off to scaru!
Stay tuned — details and pictures will be posted just after the giveaway closes, probably on Friday.
I’m assuming you will take the battery out, but it’s still dangerous. The flashlight is basically a sealed container, with no way to let air escape. When you reach boiling temperatures, the cylinder may vent violently (small explosion) sending boiling water everywhere.
Just a friendly warning. I’ve been scalded by boiling water before… not fun.
After liberating them from solid blocks of ice from being frozen overnight I boiled them with two eggs, then dumped the boiling water out and immediately filled the pot with cold water. Plenty of pics to follow after the giveaway closes.
I think you should have done all of these tests while holding the two lights.
The tests so far would kill the average human being, so if the flashlight owner is dead, who cares about the light itself? LOL.
I just got to play wid ya a little bit. Time to go clean up the O-L workshop and prepare for for the incoming patients. Let's see, I will need two hospital beds, plenty of bandages, some more pills (for me).
Here’s what I have or have had that I can think of at the moment.
Thrunite TN30 NW
Peak AAA eiger with Nichia 119
4sevens preon revo (Lost)
Peak vesuvius
Eagletac T20C2 mkII with 4 or 5 modules
Eagletac P20A2 Neutral(Lost while riding 4wheelers)
Xeno E03 V3 XML Neutral (Lost)
Xeno E03 V3 XML Warm
Eagletac M2SC4 Neutral (Sold)
Jetbeam PA40 Neutral
Fenix TK70 (Sold)
Small Sun zy-c10-s
P rocket XML (broken)
Romisen 2AA (can’t remember the model, but it was stolen)
Magicshine bike light (800 lumen version, but can’t remember the model number)
Magicshine bike light (1400 lumen version, but can’t remember the model number)
3D incan maglite
3D LED maglite
