Yikes, I missed by 3 minutes, I should have wrote faster.
Will let you in because haven’t posted results yet. But you’re absolutely the last.
Thanks, I appreciate it.
Overnight in a snowbank at an undisclosed location:
What next? How about an hour in the basement sump?:
Filthy in that sump so time for wash cycle #1:
And wash cycle #2, also on Super Wash setting:
Now into the dryer:
Not completely dry so maybe an hour in the oven will help:
The snowbank did nothing last night so let’s put them in the freezer tonight. Set both lights as low as I could:
Defrosting:
After defrosting (both lights are still set as low as I could get them last night):
Now that they’re defrosted, let’s boil them with eggs for breakfast:
Both are still working although the UF-T50’s a little dim:
Let’s bake them again! At least that will dry out the UF-T50:
They seem to be doing better. Let’s see what scaru has in store for them!
I’m sure you enjoyed doing that. Admit it!
that ice test might be a different story if you did the boil test first and just threw the pot in the freezer J)
Wow! Is it a trick of light or is a bit of the chrome missing from the reflector of the T50 in this pic? Obviously the T50 is not as waterproof as the SC600. Not a big shocker there. Nice work, BTW! >)
Thats some nice testing you done there! Cant even believe either still work! Thanks for the info cant wait for the next stage!
No trick of light; it came off during the boiling.
no surprise the zlt for the win! lol…
Cool results,I am surprised the Ultrafire is still alive!I think use of quality materials will definitely show in the next set of tests,the UF reflector already peeled so I think that's a sign that I picked right.You would think water ingress would have finished it off but it didn't,round 2!!!
I will not say I'm surprised that the ZL held up better so far. I expected it would. The real test will be during the impact and shock trials. I think the heavier and probably softer alloy of the T50 body will give it the edge in the next series of trials.
excellent. my victims are one step closer >)
thats great haha… two frozen blocks with lights still going. im surprised either passed the frozen block test.
if the other testing participants didn’t delineate tests for scaru, i’m predicting certain death for at least one, and maybe both in round two!
that guy’s twisted :davie:
Looks like I "bet" on the dark horse ...... but the contest isn't over yet ...
Both are bruised, but functional. I can't believe it.
The Executioners are having TOO much fun.
Thanks for the "update" photo's ..... suspense is killing me.
This is a very unique idea and loads of FUN
Better make a call to the Doctor, (Doctor of Illumination = O-L), make sure the ER is prepped and ready to go.
Do we know what the weight (Pre-Torture, less battery) of each light ?
Thickness of O-Rings ? The T50 has a sprung a leak.
I also like this one. Full of water except for a small air bubble and the LED’s still putting out.
Pulsar:thats great haha… two frozen blocks with lights still going. im surprised either passed the frozen block test.
yeah, thats another epic pic. but a quick 1 hour baking at 200 degrees takes care of the moisture left in it
I thought the oven heat tests might actually affect any of the silicon/rubber gaskets and even melt some. But apparently not. Am I missing something here?
