The coupon codes only apply to items not discounted at the bulk rate. Since the bulk rate is usually a better discount anyway, this is a good thing.
I suggest trying the ‘BLF’ code first, as it was set up for us (I think ‘CPF’ has the same effect). According to Kyle at Fasttech, the code ‘LAUNCH’ was not supposed to be used by customers, but was probably given out by one of their staff. Give it a shot and see if it makes a difference. I suspect any differences will be minor.
Edit: corrected my confusing wording regarding the bulk discount.
I'm just about to place a fairly good size order with FastTech (FandyFire UV-S5, FandyFire STL-V6, batteries, chargers, etc). The 5% coupon code works for me, but being the budget-conscience person I am, I was wondering if anyone knew of a currently active 10% off coupon code.
Hi. Just placed order myself couple days ago. The code BLF gives 5% discounts to flashlights only. So try code LAUNCH It should give you 5% across the board for flashlights + items other than flashlights.
Thanks for the tip. I tried both BLF and LAUNCH. They both give me the same 5% discount (which is nice), so all my items must be considered 'flashlight' related.
It appears that there are only 5% coupons floating around, I wrote PM to Fasttecha and their answer was that 10% was only during their launch, otherwise it minimises their profits too much.
I ordered some Eneloop and various tweezers today. Coupon code BLF gave me 5% off the Eneloop, but not the tweezers. Coupon code LAUNCH gave me 5% off the whole order.
sorry, i just had the nitecore and a couple of batteries in my cart….but it seems to work on more stuff as well, bought some 3400mah unprotected 18650’s for 8.5$
I just double checked with an EA4 in the cart and it just applied discount to the EA4 when I added a second item. If you then try to do BLF on the second item it cancels out the PRICECONTROL discount.
If you want an EA4 then order it just on its own. Other items can’t get discount on the same order.
