The ones you ordered, the ones I have now are rated at
Operating Voltage 3.0-3.8 -volt
We already know that you saw huge difference between 3.4V and 3.8 volts on your 1W leds. So to go from 3.8V to 4.2 is maybe too much for direct drive. What do you plan to use for a cell or cells? I am using 3-D cells, Ni-MH which give me 4V open circuit. I get a 2.15A on the draw, but these are the 3W BridgeLux leds.
When you solder the new leds onto the star make sure you use a thermal adhesive between first, then solder the leads. If the led is not sinked to the star, it will over heat very quickly. 2A through those 3-1W leds is too much, probably due to over voltage. 4.2 is too high
here are some beam shots
the control, just a 130W equivalent CFL in the lamp post
now a P7 drop in driven by 4- C Cell NiCads in a mag 3D
Then get a bulb from a Maglite, smash the glass and attach the above LED, maybe with some improvised heat sinking. maybe filling the bulb with solder etc, and run it DD?
Or simply make something that resembles the metal part of the bulb. I am thinking, no mods drop it in like the terralux drop-ins.
Yes, please! Directions would be most helpful too. What parts did you need to remove from the switch? I follow directions pretty good, but figuring it out? Not this year, or any other. Very neat mod.
Thanx;
C.
:quest: O.K., I think I got it…Starting from the lower left LED, (the one closest to the solder blob labeled + , which appears to be attached to the + of the LL LED by a trace) run wires and solder the + terminals of the other LEDs, going counter-clockwise, to the blob of solder labeled +.) Do the same for the - terminals. Is that it? What must you do to keep from desoldering the original connections? I doubt my Weller 2 speed 100- 200 watt solder gun would be the proper tool, right? What gauge wire is best?
Here is another pic and where the changes need to be made
drill or cut where the blue lines point to.
solder the + wires to the locations in red
solder the - wires to the locations in black
Things to be careful of:
If you don’t drill all the way thru, as I did, make sure that the side opposite the drilling doesn’t become dimpled as that bump will cause poor contact between the star and the sink.
After the drilling (or cutting) be sure there is no short to the star.
When you solder the LEDs make sure the led does not lift of the star, the base of the led needs to have good thermal contact with the star. (The second one of these that I made I re-flowed it right onto the pad)
When you put it back together make sure after you put the lenses back in and screw down the face plate there is no rattling in the light, if hear anything loose you need to be sure the lenses a centered correctly in the faceplate.
Good Luck!
The second one I made has the 3W each white LED’s (really 2W) and I used a 2C Mag host. 2 C Cells is not enough voltage but a single 18650 is. Works great.
Your going to have a blast combing the isle ways at HD and Lowe's when they run sales. Lots a valuable parts can be found and/or modded for special use... whole new world
i’m planning on doing this mod as well! i’ve already got a cool white led bulb, and awaiting a warm white led buld, and some time, and a good/unexpected host for it…
I just ordered one of the cool white lights from daBay, now to see if I can find any teflon-coated wire in the basement.
The switch needs to be modified as in the old-timey DD Luxeon mods…cut off the top end where the focusing apparatus is, then wire the switch to the new LED unit. Positive =Center, (soldering that one is a real PITA, iirc.) Negative is the the piece that sticks up to the side. Lose the reflector, or save it for other projects.
Ahhhh,Yes, it’s all coming back to me now! :8) (I think, therefore, I mod!) This mod should work for C or D cell lights, seing as how the heads are the same diameter, and all.
Oh, yes, I can quit whenever I want to, really I can! :bigsmile:
I just ordered one of these in cool white 9w 3x3w and plan on putting it in a 2C maglite, will I need to do the star mod to make it parallel if I run it on a single 18650 cell ?? any help appreciated thanks
BTW, I made a second Mag conversion and this time I used a 2C Mag with a single 18650. My spacer mod is HERE This time I used 3 –3W cool white bridgelux that I got at FastTech. I reflowed them to the pad on the star as I don’t trust the physical contact that is stock. I really like the form factor and beam pattern of this light.
2C Mag Mod
Great thanks for that dchomak, being a newbee can you please explain reflowing The one I ordered was the 3 x 3w cree so looking forward to that coming
Also do you have any idea what tool you used to get the switch out as my 2C is not a allen key like my 2D … Cheers
The newer Mags take a Torx 8 (T8). Did you notice Lennarts post? It seems those copycat Chinese are selling M16s as Maglite replacement bulbs!
What a riot!
I just remembered, you will probably have to grind the shaft of the T8 to allow it to fit into the switch.
My lamp turned up this morning so been modding my 2C maglite this afternoon and I must say I am pleased with how it turned out as I wanted a flood light as my other mags are throwers.
I went for the 3 x 3w bulb
I made a leather spacer tube as running it from a single 18650 cell.
A few pictures.
I made a battery spacer from a nylon rod and 2 old copper pennies. ran a heavy wire through the nylon rod and drilled the 2 pennies and soldered them. works a treat.
I them made a leather cell tube (it’s all I had to hand)
and modded the tail cap spring.
I then rewired the lamp and it all fitted well and works spot on.
Big thanks to the OP for the heads up on this.
