Closed the sale - The Defiant "C" flashlight.
Thank you
Depending upon the beam profile, it might not be a peak. The calculated 1 meter readings could be increasing or decreasing as you move farther out, but at some distance they should settle down to a reasonably constant value.
Also, you want to take the reading at the brightest point of the beam. That may not always be apparent to the naked eye. Move your meter around and hunt out the hotest spot.
I could not read the meter and aim the light at the same time, so I enlisted my wife. Picture her with her back to me and the meter sensor hanging over her shoulder, on her back, while she reads the meter itself, as I aim the lights at her back. I did move the beams around and she recorded the highest reading from each.
She puts up with a lot!
Yes, especially in the case of these two lights with honkin’ big reflectors. You’d find a measuring distance that gives readings close to the maximum throw potential. Any further than that yields minimal returns.
We can use the throw equation,
ANSI Throw = SquareRoot[(lux reading*distance from lux meter*distance from lux meter)÷(0.25 lux)]
and the readings you took to demonstrate this idea.
For the 3D’s reading you took at 2m:
Throw = SquareRoot[(2490)(2)(2)÷(0.25)] = 200m
Compare this to the 335m of throw obtained by the 10m reading. The 10m reading more closely represents the true throw of which the light is capable.
I should have been more clear. 10^2 is ten squared or 10 times 10. As everyone else has said, simply multiply your meter eading by the distance squared to get equivalent 1m reading. The throw formula is a post or two above this.
does your lux meter not have a peak function?
No, it does not. It’s the one I am sending back, because it’s the wrong one.
I have that same meter. What i do is measure from 3 meters on the 20,000/x10 setting what ever that number is I multiply that number x 3 x 3. For example the jacob a60 does around 800.
So that would be 800 x 3 x 3 = 7,200 then add the zero for the x10 setting which give 72,000 or 72k
Hope this what you are looking for dont know though. Heck hopefully i am doing it correct. I just know that that is about the numbers some people are getting out of there stock lights.
I think your distances or readings are in error.
Because your second set of readings (from 10m) is 5 times as far from the source as your first set (from 2m), the lux readings at 10M should be approximately 1/25th of the readings at 2m, with some leeway for measurement error and optics. This is the “one over r squared” rule (1 over 5 squared = 1 over 5 times 5 = 1/25).
Your readings are more like 1/9th for two different lights with totally different beams which implies a consistent error. Either the two distances were actually 3 times as far from the lights or there’s some issue with the readings. I’ve done this extensively with all kinds of lights at varying distances and see nothing about your lights, either from the beam shots or the optics, that would warrant such a huge discrepancy.
Defiant C looks like its doing 77K lux. Thats pretty sweet mine is only getting 55-56k with copper added to the pill and a xml U3 1C (thats the only mods that have been done).
So this pumping out some light! Someone needs to get this one atleast!
Since I have slept, I couldn’t tell you what might be wrong. I measured the distances and did the readings, but I probably won’t go back and do any more. I am returning the meter. I think it sucks and I realize that, like anything else, you need a good one to be accurate and then it still needs to be calibrated, none of which I am going to do. I’m just going to stick to the old way. It’s Damned Bright and lights up a long ways.
I doubt there is anything really wrong with that meter. Readings at 1m can be WAY off when it comes to throwers. Go by your 10m readings and disregard the 1m readings. Like I said in your thread about “bought lux meter, now what” you probably shouldn’t be using it at only 1m anyway.
77Kcd is pretty darn good. If I didn’t have another project coming in the mail right now I’d consider it!
I’ve done a ton of readings and have learned a lot through trial and error so if you want any help with this, just ask.
No need to use your wife by the way but you’re a lucky man that she’s so willing :slight_smile:
He didn’t take any readings at 1m and only one of the lights was a thrower. And both lights were off by the same factor.
Take a look at some quick and dirty readings I took of six different lights at 5, 10, 15 and 20 feet with a $15 lux meter and notice how all, including the TN31 and HD2010, consistently “obeyed” the 1/r^2 rule, even at 5 feet.
I’ve since taken many more readings from a wider variety of lights with a better lux meter (which I’ll post if/when I have time) and have never seen readings as inconsistent as what O-L posted. That’s not a slam, I love his work and am just trying to help.
The meter does not have a peak setting, so someone has to be reading the meter, while someone aims the light at it. That’s why I used my wife for the “meter reader”, LOL.
Dead reckoning! Now that’s a system I know and trust.
Well excuse me. Two meters is still too close for a serious thrower.
i would love to buy it… but too bad i don’t own a hobby charger…
now if only it run 26650 batteries :smiley:
How does that song by the Beatles go? Lovely Rita, meter maid…
I have to mount my light in a holder on a table, then go do the reading myself :frowning:
Here’s how Fenix does it:
“Use the luxmeter to identify the brightest point of the beam pattern and record the highest indicated value. Results are reported in candela. Measurements shall be taken 30s to 2 min of turning on the device.”
Not according to the readings I linked you to, or ANSI/NEMA FL 1 (unless you don’t consider the TN31 a serious thrower).
