I have a cheap C8 with a silver/grey finish. It’s ok but I ordered the black. I don’t know about this company except that I found it using a search site called ChinaPrices.us
Can someone point me in the direction as to where to input the coupon code? Maybe its the one-hour-ahead thats messing me up, but I can not find it and I just want to go to bed…
got my order today, although I made it long ago back in early Feb it did include a 501b in silver and the cheap xml drop-in they have
Quick play and host looks good, very light has to be said but no marks or dings, threads are lightly lubed and has o-rings on all the right spots so quite happy with this
the drop in this cheap one is 5 mode (high,mid.low,strobe.sos) and seems decent enough output wise, maybe a bit of purple in the spill bit spot is nice and slightly warm so happy with that as well, pwm is ok on medium but more noticeable on low, will have to try it out when it’s dark to see if it’s annoying or not.
looks to remember last mode used as well which is good.
think I’ll use one of the faster shipping methods next time though as china post took forever, also no shipping invoice inside so not sure what the point of being able to customize one was?
Thanks for the feedback furythings. Sounds like as good as could be expected for the price. After placing my order, I wondered if I should have just purchased the $10.00 501’s from Lightmalls because you also get an emitter, reflector, pill, springs, and maybe ok driver that way.
I couldn’t find the coupon the other day either. I used it the first time no problem. I have a C8 with that same silver/grey finish. It’s not too bad it seems to hold up well enough.
I ordered this from them the other day, four AA lantern. I never did get to use the coupon.
