1500mah
Well that sounds disappointing unless they are some really power punching cells!
-Garry
Well, if they’re sony or samsung high-drain (or whatever they call it) 1500 mah, they’re borderline worth it for lights for me anyway because I am being buried alive in pack pulls. If they’re no-name chinese 1500mah, forget it. Have found the chinese ones in a couple tool packs and they have been miserable.
To crack the pack or not to crack, that is the question. Hmmmm.
meh… dont know if i should bother if they are 1500 mah…
The 1500 high-drain or high caps or whatever they’re called are really pretty good. Can’t tell the difference in some of my lights with those 1500s vs 2600s.
Regular 1500 mah cells will barely light a torch, but these tool-pack cells are designed to put out a lot of juice quickly and are NOT normal 1500 mah cells. There are some discussions on BLF about them. I think HKJ even did a test on some, but maybe I’m dreaming that part.
take one for the team! J)
Do it! . . . Do it! . . . Do it! Do it for the good of the BLF community! (And to save me from wasting my own money!) :)
-Garry
54Wh / 3.6v = 15000mAh
15000/mAh / 10 = 1500mAh
OR
15000/mAh / 5 = 3000mAh (seems unlikely)
The Sony IMRs are really good. I’d do it if that’s what’s inside. Problem is I probably won’t find a discounted pack in the boonies. web says these aren’t in inventory or sold at my local store.
im going to go check my local HD in augusta me. if they have them on clearance im sure all do… if the others have any stock left, thats another story.
im probably going to buy one, and wait to see whats inside before i crack it open. yes im cheap that and i got a hole lot invested into another hobby and i cant really afford to take a hit with batteries right now
Okay, the tension is building here at battery pack central. We have the main cover off. And we have ……
STOOPID security torx screws. Had to drill out two holes to get a driver in there …… But I drilled out the holes because even with two screws out, I could pry the pack slightly open. Inside I could see, in all their glory ……
Did you hear the one about the watermelon salesman and the farmer’s daughter? Well, it’s late one night in the Texas gulf coast and this nattily dressed dude in a straw hat and ……
Did I see a wink of red inside there? Yup, cover is now off and we have —- YES!!!——- red Sanyos!!! Now to see the numbers, I will have to go in deeper.
On a side note, there is a button on the side you can push to check charge level. Don’t have to worry about getting a pack with dead cells. Just push the button and see the charge level!!!
Okay, I now have to pull them outta their cage to get at them, so I will be gone for a while. But I will report back about the farmer’s daughter …. I mean the mah on the Sanyos.
Did it have them marked online as in store? Neither of my local hds have them marked as in stock online
Website says Item not sold at store. but the home depot inventory checker shows they had some near me Checker SKU: 342082
I got 3 for now and the markings on the case show they were assemble on 2011 Week 52 . The cells are Sanyo 18650W2
No, they were on a clearance shelf in garden by the string trimmers, which is what the pack is for. I have the cells out and am looking them up now. TEN bright and shiny Sanyos. All 3.60-3.65 volts.
I do have to say that this pack was the hairiest one I have disaasembled and I have taken apart quite a few at this point. Definitely NOT for the timid.
The cells are stacked neg pole to positive in the cage. You MUST be extremely careful when stripping off the contact tabs. I won’t say I was sweating bullets, but there were a couple minor puckers. And one minor shower of sparks. Really. I slipped.
To remove them from the cage, you must pull off the tabs, which is extremely difficult to do without contacting the opposite pole in the next cell row. Hard to explain, but you will see it in person if you decide to do the deed.
Now to see what these are. I assume they are 1500 mah. Back in a bit.
Where did you see the dates and the cell type on the case? No dates or cell type on my case. Would have saved me all this aggravation!
Ok, I guess I'm heading out to HD tonight. :P And guys, please don't post in the slickdeals thread so I can get some. :)
Oh I see …. On the battery case, not the pack itself. yup 18650w2.
Found one. Top shelf burried with a bunch on random stuff lol. Guy had to get a ladder to get it.
Yup on sale. $23.14 after tax. Only shows 1/4 full though…
I didnt separate the cells yet but on the top of the case near where it says positive and negative is a stamp mark that says 2011 52-ys and 2011 44-ys
1500 mah as suspected. Gonna dremel off the burrs and charge em up and see how they do. Never had new 1500s before. The used 1500 sonys and Samsungs seemed to work pretty good in the lights I tried, but I never really did any scientific load tests.
However, I DID run some in my test flashlight and ended up with 3.80-3.90 volts in the cell after 30 minutes, which is pretty much what I end up with for 2600s. Someone with more li-ion-load knowledge than me will have to chime in on whether these are really comparable to a “normal” 2600.
Mine was also 1/4 charge on the little led meter on the pack. All cells were 3.6-3.65 as I said.
What will be great in a couple years: The new 2600 mah tool packs will start going on sale and showing up in recycle bins. Those will be a treasure trove!
Off to dremel these.
