thanks for the review Keltex, I have one of these on the way too (OP though). If I don’t like the beam, hopefully a 20mm TIR will drop right in. Good tip about the tail cap mod, but what does it consist of exactly? Putting an o-ring between the boot lip and the tail cap to raise the switch and boot inside the light? I don’t really need it to tail stand, but I will be using a variety of cells with it so a stronger connection would be helpful.
That's correct on the tailcap mod. I actually cut the lip from another discarded tailcap boot and used it since I didn't have an actual o-ring of the appropriate size. You just need a ring that will fit around the end of the tailcap but not roll past the lip. That will move the boot/switch assembly back slightly increasing the recess.
cool, thanks! I’m looking forward to getting mine and putting it all together. It’s going to be a bedside/ camping/ evening walks light, so it should be just about perfect
thanks for the review, that’s a great price for an 18650 sized edc host. handy too as I’ve recently had a few requests. At this price I could build a few with cells and charger at a nice price that doesn’t scare people off.
I’d probably go op with a 6*7135 driver and nw/cw choice, although I have found most are taken with the nw option (I demo on cars/engineering situations, the lessened glare and better rendering of nw appeals).
mat, can you post back here with your impressions of the op set up please?
sure, will do gords I’ll be putting a NW XM-L2 T5 in it with a 2.1A Nanjg, hopefully programmed with the BLF-VLD or lupodrv firmware. My wife forced me to do it, after she appropriated my Romisen RC-G2/ Nichia 219 bedside light. The sacrifices I make…
With OP reflector, 4x7135 driver and XM-L U2 1C LED:
Thanks for the review. You should write review somewhere in the title. I almost didn’t check this thread out, but I read all the reviews.
cheers neckdo, that sorts it for me.
Nice review thanks for the information!
Kind of reminds me of the old TR-801
What I like about this host is it can take protected cells whereas the X-Power brother does not. I used a 8*7135 and when it has active cooling during skiing it barely gets warm, but of course gets too hot to hold if indoors with no circulation. I think I have a bad ground from the driver to the pill as sometimes it just blinks and goes out like the circuit has been opened even when the battery is known good. Once I get that problem licked this will become one of my favourites for skiing and biking unless the M2 host I ordered to use with the same driver beats it out.
<edit>deleted... wrong thread.
TSellers - you might be having battery bounce, particularly if your intermittent problems happen while you’re skiing. Try raising the switch inside the tailcap like Keltex did to increase pressure on the spring. It’s a pretty common problem among mtbers using torches for night riding and a stiffer or longer spring usually fixes the problem.
I got my C20 yesterday, looks really nice. Threads are well machined and run smooth, o-rings are lubed as stock. I haven’t had time to pull it apart yet (busy building a milling attachment for my lathe), but I’ll get stuck into it when my programming clip arrives. The only downside I can see is that the pill material under the star is pretty thin. I might see if I can add some copper to the pill to help out with that - I just found a nice 2in copper pipe cutoff which should help
Thanks Matt,
I’ll give your suggestion a try. One of the things I noticed was the light powers on as soon as the tailcap makes contact. I also noticed my solder job for the ground looks iffy, I’ve tried 3 times, and even scored the edge of the pill with a dremel, but I’m just not getting a good weld there. That’s why my theory that the battery bounce is actually moving the driver inside the pill. When I check continuity it is always positive but that doesn’t mean it just hasn’t reseated itself when I unscrewed the cap.
So if I do get this problem solved, now I wondering about something else. I see that FT has a 4.35 charger SKU’d up now. If I were to use a 4.35v cell with the 8* driver do you think it would result in any brighter light, or does the driver regulate it so that it would not make any difference?
it would (in theory) keep the light regulated for longer, not brighter
Thanks janko, think I’m just looking for a reason to justify starting to use the 4.35v cells!
no worries Tracking down an intermittent electrical problem is a pain in the bum, that’s for sure. Another way to troubleshoot would be to smack the light when it’s on with the tail cap on and off (with a nail or something between B- and host), as you could have something not quite right in your switch too. One way of making a good -ve connection on the driver is to just solder a piece of bare wire between driver -ve and pill. That might help too.
Thanks, co-incidentally I just finished soldering again. Also this time I didn’t like the look of the solder bridge on the star that tells it the mode, so I redid that as well thinking maybe the mode was getting confused with a bad solder. So I tried your suggestion and gave it a few smacks while it was on and all good, but in the past it fails after it’s been on for awhile so I can’t be sure yet. I sure hope it works this time because for the first time the emitter is perfectly centered which is nice.
Also since I posted earlier I did find a previous thread where they said this driver does not really benefit from a higher voltage feed, and it can be worse in fact, apparently at 6v for example it’s only 60% efficient with tons of heat as the result. So in fact I’m thinking maybe the best cell for this light would be an a123 18650 LiFePO4 cell and not a Li-Ion.
Update: the intermittent problem was due to bad ground between driver and pill. Seems OK now.
Thanks very much for the review! Frontpage’d and Sticky’d.
great, glad you got the problem sorted. My build is still stalled, but I’m hoping to start making progress this week or next.
Thanks Matt,
BTW there are a couple of features I’v some to appreciate with this host now that I’ve had a chance to also do the Convoy S3 host as well:
- Can unscrew the top section to access pill easier.
- Pill has better slots to use to extract or insert it, and you can screw it in from the driver side of the pill. (S3 has tiny pin pricks that my circlip pliers cannot hang onto and you have to screw it in from the LED side, on my first attempt I ended up transferring heatsink compound onto the LED).
- Pill has keyway slot to match tab on the Nanjg driver (you have to grind it off, and discard the included retaining ring, if using Nanjg with the S3).
- The finish is more scratch resistant ( EG: when compared for example to the black of the XPower host they sell).
- Tighter spot than the S3’s OP reflector.
In my mind the areas that could use improvement are the thickness of the metal, it sort of feels like a tin can for guage, and the drivers on the two that I have built needed to be sanded down to get them to fit into the pill. Maybe even the finish could be upgraded, and I do like that glow ring under the lens of the S3. If they did all those they could charge more, I think it would still be a great host at twice the price, and even better still if they were able to find a different switch.
I’ve got a Convoy M2 host arriving today, so looking forward to giving that one a try.
Edit: Sorry about the numbering on the list, for some reason I couldn’t seem to get it to number consecutively.
