FastTech C20 DIY EDC LED Flashlight Host
Summary:
| Battery: | Single 18650 |
| Switch: | Reverse clicky |
| Modes: | Any you like! |
| LED Type: | None |
| Lens: | Glass non/AR |
| Tailstands: | Yes, after mod |
| Price Paid: | $6.65 before discount |
| Date Ordered: |
Pros:
- Good quality machining
- Nice anodizing, very pleasant shade of gun-metal gray
- Fits protected cells
- Reflector works well with XM-L emitter
- No sharp edges, crenelations, or coarse knurling to wear out pockets
- Takes standard 16mm emitters and 17mm drivers
Cons:
- Slight blemish on the reflector (doesn't affect beam/use)
- Slightly too large for an EDC
- Smooth finish, not very grippy
- Longer driver spring or tailcap mod needed to use Nangj driver with unprotected flat-top cells
- CREE branding etched onto side panels - Sorry Nichia modders...
Just a bit about this light:
I purchased it a few weeks ago from FastTech. This unit has the SMO reflector...
http://www.fasttech.com/products/1618/10002463/1181700-c20-diy-edc-led-flashlight-host-for-cree-xm-l
...but the same kit with the OP reflector is available as well:
The specs on the FastTech website were correct as the light measure 115mm x23mm dia. as stated.
I assembled this light using an XM-L U2-bin emitter and 2800mA Nanjg 105c driver:
The driver was set to the 2-mode High/Low configuration. The Low mode on this driver is far too high for normal around-the-house use, and could benefit by having a moonlight mode. On high, this light is extremely bright, but understandably floody due to the small diameter reflector.
Although this form-factor is referred to as an EDC, I find this light slightly too large for that purpose. It is easily small enough to drop into a pocket if I need more light or longer runtime than my EDC can provide, but is just to heavy for EDC pocket carry. The TrustFire F20 I am currently using as my EDC is much more convenient and unobtrusive:
I like this as a go-to household light as it is compact and can be dropped in a pocket if needed, and the low mode provides sufficient illumination for normal everyday tasks. High mode is available, and with the 2800mA drive I chose, pushes the LED very hard for this small host blasting a wall of lumens, but at the expense of rapid heat build up. The pill obviously does a good job of tranferring heat into the body of the host, but with the small amount of mass available, this light rapidly heats up. I've only left it on high for a few minutes while holding it in my hand, but I'm sure it would get untouchably hot very quickly if left unattended for an extended time.
The small-sized stock spring on the Nanjg 105c driver prevents shorter non-protected flat-top cells from making good contact. The light works properly, but any shaking will break the connection making the light change modes. As the light comes assembled, the tailcap boot protrudes beyond the end of the light preventing tailstanding. I removed the boot and did the o-ring mod. This had the double-improvement of both recessing the tailcap to allow tailstanding and also tightened battery connection so my cells work properly now. Both my laptop salvage Sanyo cells and Protected Trustfire cells fit.
Overall, I do like this light as a pick-up-and go light, but it doesn't have much advantage over a P60 host. I won't be using it as an EDC, but it's great for quick tasks outside at night, tailstanding on low for use in power outages, or keeping by the bedside. It's a good option for someone wanting to get into flashlight modding/building as it's easy to work with and has everything you need to use with your own emitter/driver combo.
