iTP A1 EOS
iTP A1 EOS
Tank007 M10, bought off the streets of HK. My first 'modern' LED, it's still my edc.
I'm kinda itching to find a good clicky replacement though. The threads are so loose it tends to go off in my pocket now (and it quickly gets hot!)
Edit: I'm not sure it qualifies as a microlight. it's a bit bigger than an 18650, even after you strip the magnetic tail off.
Thanks everyone for his opinion. Seems that iTP has a great number of fan!
iTP A1 EOS Stainless steel.
I'm not sure about running a 10440 battery in the latest incarnations of the ld01. I think some the newer versions are current controlled instead of PWM regulated.
It was my Quark MiniX 123 but now it's my wife's XTAR Wk20. So, since that light is no longer mine, I guess it's still the Quark.
onewk20equalsonehappywifeFoy
My Tank007 TK-703, modded to run DD from a single 10440 cell is almost always in my pocket. It gets warm quickly but puts a lot of light out for such a small sized package. It has a decent aluminum SMO reflector so it has a surprising amount of throw for such a tiny pocket light. I try to run it in short bursts only since it gets so hot and I'm sure that DD isn't good for the cheap DX 10440 I have in it.
I'm looking for the "smallest-brightest" Flashlight with "Wow-Effect" under $ 30. Is the iTP A3 Eos still a favorit (even the upgraded version) ?
One of my custom Micro MiniMags with an XM-L driven at 2A and powered by a 14500 making 700 lumen sent through narrow TIR optics. Able to flood a room or back yard and still hit a tree line 100 yds out.
4sevens Preon WAS my brightest/smallest with R5 and 10440. Too bad 10440 cells are what they are...
Hated it: too stiff to use as twisty, clicky was also crappy.
iTP A3 did it better but oh boy, that low PWM of older version...
Now I have even smaller one but less WOW-factor yet tons of runtime DQG Tiny II :bigsmile:
not exactly an EDC light or a tiny light but my UF-2100 is amazingly bright.
As for tiny lights, my iTP A1 is surprisingly bright for a light that small.
N-light B3 / ITP / Maratac [ all AAA ]
The stand out is the N-light B3 - its superbly regulated , and is my go to AAA light .
I really think the beam profile of the ITP A3 is one of the best in it's class .
If you're into that sort of thing .
What about the Tank007 TK-703?
Based on what you guys think, I'm going to order the ITP A3. I just have to find the best price.. Edit, maybe the A1???
The Tank E09 looks it could be in the running soon. It seems it handles 10440's too.
However the new Xtar WK21 looks like it may dwarf everything.
For under $20, the ITP A3 with 10440 is pretty hard to beat size/output/price wise.
You'll love it Glen. http://www.shiningbeam.com has some stock left.
I got mine from him. Good seller and stands behind his stuff.
I have the 1-mode which is even smaller than the multimoded one.
I actually ordered one from them last week. I like my iTP A1 but I wanted an A3 because it's even smaller. And the fact that it uses AAA batteries which is a big advantage if you are going to travel with the light. I plan on using the A1 as my EDC at home and then taking the A3 as my EDC when I travel.
Also , the A3 clip can be reversed and clipped to the bill of a hat for a dandy headlamp .
