I need help. Looking at soldering stations there’s a couple kazillion of them out there. How do I know what to get? I don’t know the names and certainly not the models, so will someone please look at these 3 and give me a heads up?
X-Tronic one is a Hakko clone. Usually good.
The second one is a full station, with hot air. interesting… Edit: This looks good, but overkill for soldering driver chips. Unless you want to spend $100+ on an iron, the HK or MCM option makes the most sense. I may give this a try though. It’s Hakko compatible iron with hot air rework… The genuine models of these are in the $600 range.
I do not recognize the third one.
The one from the Bunkster is probably the best deal for US delivery. The HobbyKing one is in stock. not sure if the MCM one still has the deal on, but Tenma is a good brand of Hakko clone.
Amazon.com doesn’t ship those stations to Canada, and I can’t find anything reasonably close for that price on Amazon.ca
Anyway, Ouchyfoot, congrats on a job well done! looking good.
As for stacking three high; it can be done, but I wonder about heat buildup in such a small area. You could put two on one side and two on the other side for four extra, 12 total.
You have a Weller station; nice.
I like Weller, used to have them at work. I have a Hakko 936 here, which I like too. I never used a clone but they get good reports from others.
Thanks relic. I've only built one light so far. I tried a P60 first, and trashed the whole thing. My $7.50 iron could hardly melt solder. I almost gave up. I decided, "I want this hobby", so I bought the Weller. With zero soldering experience, my first build came out perfect. I think I could paint a portrait in solder with this station. My only regret is that I wasted $7.50 on the first one.
Im looking forward to your "How to use copper braid" tutorial.
If anyone could do a tutorial on how to pot a driver, I wouldn't mind.
You’ll like it. Having control of your heat makes a huge difference. I was looking at that one too. The reason I went with Weller was the availability of parts and service in Canada. Hakko isn’t very prevalent here. The Weller Canada facility is just down the street from where I work.
But it was just too high. The Hakko at $83 with free shipping made it work. And wouldn’t you know, right after I ordered it I found the Digital model with readout for $7 more! Aaagghh. lol That’s ok, this one will be Way better than anything I’ve ever used before. I also got a 1.2mm bevel tip for it.
The Weller was like $123 + $18 shipping, hate it when the shipping makes it a no-go.
I will probably get the station and the AMC7135’s about the same time, should already have the new drivers if all goes well. They could all come on the same day and I’d be happy!
Hmm, I wasn’t aware of that. I guess that’s because I buy tips online. I’ve had my 936 so long I do not even remember where I got it. I’m due for an upgrade/second station… a hot air rework station would be really nice for what I typically do.
I found a Canadian seller with the YiHua 853D with tons of accessories for C$130 + tax (local seller) shipped. Pulling the trigger…
Pretty cool station. Video review:
Edit: added tax, forgot I will have to pay that because the seller is in my province. $147 now…
Wow. That’s way over the top for someone with my meager needs. I sure hope you didn’t get caught up in our purchasing chit chat, and sowed the seeds of upgrade.
No worries. I’ve been after one for a while. Without the tax it was the best price I could find. With tax, it’s only $5 more than the best China or US price I could find, and I’d still have to pay (an unknown amount) of duty/tax, so it’s good. The others didn’t come with extra heating elements either. That is a job saver when something fails.
There are cheaper models too, but none that caught my eye like this one. I like the UI, the extra parts, and the little power supply/meter built in is nice too.
Good find. I was thinking hard about that XTar with hot air station for doing shrink wrap and stuff but in the end I thought a better quality straight forward soldering iron would suit me best. Still cost a little more than I’d have liked, but the way I’m getting into flashlights it’ll be well worth it. In years gone by it would have sat around unused but probably not so much these days
Hakko is a good brand, and there are tons of brand name and generic parts available online. It’s a good pick for sure. You can just about do anything for flashlights with a 60W solder station. That is the updated design too. I’m undecided on the look, but the function is definitely there.
The key for doing better solder jobs is heat control. Too much heat and you stress the parts. Not enough and you get cold solder joints, broken components, and a lot of frustration.
I’ve managed for almost 20 years without the proper tools for SMD rework; time for a treat.
I generally use the lowest temp that melts the solder smoothly. If the solder doesn’t look shiny when it sets, you do not have enough heat. A cold joint looks dull because the solder crystallized when it set. If this happens, turn the heat up a few degrees, remelt the joint and let it set without having the parts move while setting.
For general electronic soldering, 350C to 400C should do it.
If you use lead-free solder, you will need to be closer to 400C, maybe 425C. My suggestion is to use 60/40 tin/lead rosin core solder (0.6mm, 2,2% flux). It flows like a dream and will keep your tip tinned with only a wet sponge for cleaning. Others swear by 63/37 core solder, but it’s not for me. Leaded solder may not be available everywhere (EU?)
For sensitive situations (i.e. semiconductors) I max out at 400C. If it’s just wire, pins, etc. and I cannot get a good joint I’ll go higher. I will not leave the iron above 400C as it tends to mess up the tip easier, making it difficult to tin.
