if 4p, would need to mod battery config or find a 3A+ boost driver. Aside from big money for a taskled driver, there is not such beast afaik.
From aliexpress I can see it is parallel battery config. 4P1S.
That was my hunch.
EDIT - this must be the photo you saw:
-Garry
Yessir! Just couldn't get the dang photo link to work and lost my patience :-)
That (4p) with an electronic switch on the side… I’d buy it instantly and swap the driver.
I know what you mean, some of these sites make it darn difficult to figure out their photo links! I've learned a few tricks recently.
-Garry
You sure must have. Thank you by the way. It was kind of you to do that :-)
I think you guys are right… that’s probably a normal clicky switch, which is reasonable since listed current rating is only 1.8A.
Unmodded, this will be a spectacularly underperforming light for the price. But of course - it’s the modding potential that hooks. Wonder who’ll cave in first.
You can probably count on it being the normal 5 mode driver with pseudo-direct drive on high, somewhere around 2.5A
4.5a xp-g2 on sinkpad, awesome thrower. 8)
Good for folks that need the extra run time, I guess...
dedomed of course!
with 4x 3400s you would get around 3 hours on high!
If it was an electronic side switch, I’d buy it in an instant. I bet you could put the battery tube from a SRK on it and have a 4P twistie
It’s just a few cuts, wires, and solder blobs away from a 2S2P battery config.
I’m on the edge with this.
Two options for me:
- XM-L2 (possibly dedomed) on copper at 5A+ (no battery tube mod for this)
- MT-G2 at 5A+ with battery tube mod
If it was an 80mm head, I would have ordered already. I like this format, although this one is a bit on the long side.
Group buy. $30.00?
Group buy. $30.00?
Id be in this! Make it happen.
Since Sanyo ZT’s and FM’s stay above 3.5V during most of their discharge cycle, I wonder how well they would drive a +5A 7135 based driver with MTG2? Only 1.25A per cell…
MT-G2 is a 6V emitter, so that’s a no-go on 4P1S cell config. It may work on a 2P2S config though. The 105C has been shown to ‘tolerate’ a 2S configuration for a while anyway.
Yes, but what driver provides 6-8V at the emitter while being driven? I randomly tested a few 2 x 18650 lights and they provide 3.1 - 4VDC at the emitter while powered on. I assumed that all your MTG2 mods were being driven around the same voltages.
