I did a 14*7135 driver and got 4900mA with the DMM in series with the standard Nanjg leads with a UR18650GM at 4.15V (offload measured). I think that driver is simply bad, too much drop in the circuit.
The silicone has advantages for flexibility, but been finding this stuff harder to solder - dunno if it's this particular wire or what, that's why I got the IOS wire on order. The teflon coated, silver tinned solders up real well, but turns stiff, sometimes good, sometimes a problem.
I received my I-O 22ga wire the other day (‘red’ and black). Looks fine, nice and flexible. The red is more of a pinkish-orange, but who cares. I already had 20ga, but that is sometimes too thick for certain lights (HD2010 reflector, I’m looking at you).
I picked up one of the V10+ 5A ramping drivers on a whim, it's pretty disappointing. I haven't put it in a light yet (and probably never will), only bench tested it so far. Current was low with only one good cell so I thwacked it with four Samsung INRs in parallel... current went up just a little but still nowhere near the rating. I can't get it to feed more than 3.8A to the LED no matter what I feed it with. And the UI is about the clunkiest thing ever.
Also, it won't fit into a P60 pill unless you solder on an extender ring first, though most uses will be in something beefier than a P60 (but then, it doesn't really need to be 17mm).
Interesting piece on paper, in person not so much.
Response from fasttech was that for them, the driver works fine.
Offered replacement or refund, chose replacement.
I haven’t finished yet with that wannabe 5A driver.
I have not found a direct drive driver which gives 5A+ with one cell and xml2 until now…
I ordered a lot of them and a Samsung inr for my tests…too sad.
The FETs they use have to much resistance or the design is crap, I am not sure why these drivers often have so much devices on them. Controller and FET should be all you need, perhaps some resistors for under voltage protection….
I just swapped mine out and put the East-092 back in. It increased the output sery slightly. I think I had it close to 5A with the mods. I’ll put it in the other HD2010 and mess with it some more. I don’t like how the ramping mode is all on its own. I want to have the ramp to set one or more traditional modes. Using the ramping to change output levels in real time is pointless and takes too long.
I'm think'n 4.3A-4.4A or so is the limit for XM-L2/SinkPAD single cell lights from what I've been seeing now on HD2010 mods. That's why the T08 is so nice - wonder if you'll get closer to 5A on 2 or 3 parallel batts with this driver. Maybe I'll try it in a T08 or 7G9.
Relic38 could not get 5A at 4.20V with a power supply I doubt 2 or 3 cells in parallel would do it. And that was at 4.2V, which you'll never have on on-load cells.
No, at least mine won't. 4x INRs in parallel, still wouldn't pass 4 amps. And that was testing with a XM-L U3 on an AL 16mm bolted to an old CPU heatsink. Current went up as compared to a single cell, but still short.
They didn't have the 4A version listed when I got mine, only the 3A & 5A, so I don't think it could be a case of a parts mixup.
ST-50 flashlight, 4.6A driver designed for sst-50 led, aspheric lens, sinkpad & XM-L2.
I am not an expert but I strongly believe that the reflector designed for the sst-50 led is not helping the XML.
Just for the record. I placed a V10+ driver into a Convoy M2 host with a XML-T6 3C emitter. The ramping mode worked for awhile, and then quit. I had one mode left that works: high. That mode worked well last night at midnight when it was the only light I had with me and I had to enter a closed area so I could go and retrieve Reconyx surveillance images as follow up to our agency response to a local Cougar attack. It seemed to heat up a lot quicker than the same config as using a Nanjg driver at 2.8A, so I did a tailcap measure with a clamping meter. I got 4.4A at the highest reading. On a Convoy S4 with the Nanjg 2.8 driver I read 2.9A. I used fully charged Panny NCR18650PD and Samsung ICR18650 cells for this test and they were the same results.
So this has left me wondering, if I have a specialized application where I’m satisfied I can provide the cooling required and I only need one mode, would this V10+ driver be the only way I could achieve the 4.4A or more, or do I have other alternatives such as going the direct drive route? As mentioned this seems like a pretty flawed driver, and my experience would seem to corroborate that, so it would be nice to find something more reliable.
