http://www.leddna.com/copper-base-pcb-heat-sink-mcpcb-for-cree-xm-l-xm-l2/
Added. Reminds me of the one Fasttech and LCK-LED sell. My guess is that it has insulation layer, but someone please buy on confirm. That goes for the ones from Fasttech and LCK-LED tooā¦
I have also added MK-R on copper MCPCB and bare. CW, J2 BIN. (highest bin!)
I have also added a simple overview of the different BINs in the MK-R page. Did not look too good, but it gets the job done.
Ft confirmed no conductance between the top pad and bottom, so the FT ones definitely have the insulation layer. See discussions on their product page.
Thanks. Did minor change to comment on those.
Ill let the ones from LCK-LED and LedDNA be questioned until someone have confirmed the same. I assume they are the same thoughā¦
Intl-outdoor have now gotten XM-L2 T6 3C on 14/16/20mm
They have also gotten XP-G2 R5 2B and R5 3C on 16/20mm
All added to spreadsheet.
excellent initiatives guys you all have here!
thanks for the sharing
I donāt know if this is right place to ask.
is there anyway we can distinguish xml bin from the emitter physical attributes?
Iām trying to tell which of my light is T6, U2 and U3 except reading it from the box or label on the light. maybe the labelling is just not true.
excellent initiatives guys you all have here! thanks for the sharing I donāt know if this is right place to ask. is there anyway we can distinguish xml bin from the emitter physical attributes? Iām trying to tell which of my light is T6, U2 and U3 except reading it from the box or label on the light. maybe the labelling is just not true.
Unfortunately there is no way to tell by looking at the LED, you'll need to trust that your source is reliable and not falsely labeling bins.
There are sadly no way to tell the BIN. Only a light meter could tell the difference if you have the emitters you are comparing driven at the same ampsā¦ At least, that should tell which is brighter than the other and thereby indication of BIN. Especially if you have one trustworthy emitter to compare with.
Famous name brands should be trustworthy. The majority of cheap Chinese light I would not consider trustworthy.
I think there are a few stores out there that can be questioned even for the emitters added in the spreadsheet. Im thinking specifically about several of the XM-L2 U2s that was early available. ( I would consider Illumination Supply the best source for XM-L2 U2)
unfortunate that there's no way to tell without tools.
eventhough having a light meter doesn't really can tell accurately due to the different temperature color, it can lead to some grey area. anyway this might be a concern when there is different information regarding particular product let's say label in the box, label in the manual or warranty card, label in the light itself and label in the seller and manufacture website. even decent manufacture can use box/manual/card with different description to save some cost.
I got some XM-L2 U2 1A's that have that familiar yellow glow around the center beam - obviously 1B or 1C's, but KD said they were 1A's when asked... I believe they are the Mouser batch's that don't specify a specific tint, just a grouping, and since they "might" be 1A (or 1A is the first listed), they just say 1A.
"I trust in IS", next trustworthy source is Hank for me...
I got some XM-L2 U2 1Aās that have that familiar yellow glow around the center beam - obviously 1B or 1Cās, but KD said they were 1Aās when askedā¦ I believe they are the Mouser batchās that donāt specify a specific tint, just a grouping, and since they āmightā be 1A (or 1A is the first listed), they just say 1A.
Or they just licked a finger, pointed it up in the air and depending on the way the wind was blowing they decided upon BIN/TINT within the CW range. The other hand was probably used for crossing fingers and hoping for CWā¦
I think its their way of deciding what specifications products will get. I also think their customer support work by that philosophy.
I personally donāt consider KD trustworthy of anything. Their customer support come with more false info than true based on my experience with them.
āI trust in ISā, next trustworthy source is Hank for meā¦
+1
When that is said. FT gets most of my money when it comes to emitters, just because of price. They seem to be fairly accurate when it comes to emitters.
TINT/BIN combo vs PRICE decides who gets my moneyā¦
Nice find Flashpilot. I added it.
This colorful XM-L and various others emitters have also been addedā¦
http://www.led-tech.de/en/High-Power-LEDs-Cree/CREE-XM-Serie/CREE-XM-L-Color-on-Star-PCB-LT-2074_120_170.html
Its a shame that LCK-LED did not have the XM-L2 in 3000K when I recently placed an order on various emitters. I would have bought oneā¦ If i buy more from them in the near future I will add one mounted on copper. Just to check it outā¦
All XM-Ls they sell can be mounted on 16/20mm copper star for 1$ extra.
I have added WW XM-L2 and done some price fixing/update to various stuffā¦
Also, various other small stuff have been added in the past be me an other users. Thanks to everybody who contribute!
Thanks for keeping the database up to date and tidy for everyone to use. Since it seems to keep getting messed up, perhaps you should consider locking it with a password and distributing that pswd to a select fewā¦ just a thought.
Thanks. If it becomes a problem I will consider. But so far, its seems more and more people are contributing.
Small stuff I easily fix. And the larger mess that have happened to some sheets looks to be some sort of āformatting errorā or something. Thanks to Scaru I now know how to easily restore it.
Just that people post links to new emitters (and MCPCBs in this thread is helpful to the whole community.
Its nice to even see people (okay one guy, so far) from CPF joining in and seeing the value of the spreadsheet.
Nice Work! THANKS!
Dan.
Updated links/prices to the copper MCPCBs from intl-outdoor.
In the spreadsheet I also see that vestureofblood now sells 16mm Sinkpadsā¦ A nice option for US buyers who want fast shipping, or for buyers in general who needs 10mm copper boards.
Same good (shipping) price for international buyers too.
Updated prices for Kaidomain - $7.27 each now - not bad, but I got mixed results, some looked like 1A, others looked more like 1B or 1C.
Nice price for XM-L2 U2 (if they are U2s).
I updated the U2s from lightmalls. They are now down to 8,90, so not much lower than beforeā¦ Cant compare with KD in terms of price.
For those who have been looking for a very cool white XM-L2.
XM-L T6 0D 7$ from cnqualitygoods.
http://www.cnqualitygoods.com/goods.php?id=1831
They also have other CW T6s in stock, but I cant be bothered to add them since several other stores have similar products at same prices.
I dont think that many people care for XM-L2 T6 CW? Unless its T6 0D and for de-doming purposes or somethingā¦
May be cheaper to buy from fancyflashlights (due to free shipping), but I was not able to access their site.
