Have a look at this icharger. For a few $ more it's much better quality and features (more accurate balancing, among others). It has higher discharge current that is needed for capacity testing. You may also want to read this excellent thread on serial charging with hobby chargers and the icharger specifically.
It's the same one I'm using. Although I'm not using it anywhere near it's capacity, it's balancing accuracy blows away my cheap Turnigy Accucell 6. Highly recommended!
From what I've been reading, it's not a great idea to balance charge batteries with vastly different remaining charges. I imagine it'd be even worse if charging different types of batteries. So to bypass those issues, I might just get this charger or something similar.
To give you an idea of my charging needs in the near future... After a night bike ride every other night, I'll need to charge 4 26650's and 2-4 14500's, all with different charges. Right now I'm charging half that many with a pair of single bay chargers, one of which charges at 360 mA. That's already driving me crazy. I'll go bonkers trying to charge twice as many batteries.
I think that would depend on how 'vastly different' you mean. With a quality charger that has good balancing accuracy the biggest downside is that it's going to take longer to bring the weaker cells up to the stronger ones. But you do need a decent charger.
A case in point: I made a balance charging harness to charge two cells today. I used it to charge two cells, one at 3.83v and one at 3.90v. My charger is an X-charger B6 and it charges/discharges one cell at a time very nicely and accurately. But I found out today that it's balancing accuracy is crappy. The two cells finished at 4.1 and 4.18 respectively, so they started at 70mv apart and finished 80mv apart!
I'm hoping for much better results with the icharger that I will be getting for Xmas.
I just got in one of these… :party: Dual channel with up to 10 lipo cells per channel, can charge at up to 70 amps… You can also charge on one channel and discharge on the other at the same time. I’m driving it with a 28V/11A supply (but have a 28V/60 amp one if I need more juice)
I wonder what an UltraFire cell will do if charged at 70 amps? J)
The only way I’ve known to get a discount from HobbyKing is to open the page up with the charger. Dont put it in your shopping basket. Let the page sit open and sometimes you get a popup in the bottom right hand off your screen with a reduced price. Good luck.
Yes, I noticed that on several occasions, but no discount now, I left that page an hour or more sitting open, they would probably only give me 2$ or so anyway...
So are you satisfied with this? It’s on my list since I bought the iCharger 106B+ but I don’t need just yet. Most probably I want to buy it because it looks cool…………oh over-consumption disease.
Yes, it’s a very nice charger. I have not had much time to play with all its gory features, and so far I have only driven it with a 300 watt power supply.
