I wonder how much different the beam pattern will be from the smooth S1100 reflector retrofitted with the same LED... mine didn't change between the XML->MTG2 except that everything got BIGGER (and prettier). It still has the same tight center spot, with an intermediate, erm, spot, around it, and then the soft outer spill.
edit: Also their description of the UI seems different, I can't work out if it's really been changed. It sounds almost like the blinkies are hidden? I can't make sense of it...
Doesn't look like it's available yet on Solarforce sales but when it is (if it doesn't cost as much as a car) I'm all over it. Foy needs to get MT-G2 unstupid.
If it's the same driver as the XML version, it's 3.3 amps at 6.whatever volts. If they're using a copper MCPCB, it'll be a good bit higher than what's in Match's test graph. (the S1100 uses a pseudo-copper board, with dielectric between the LED & base)
So it's actually conceivable (even based on Match's graph) that this light is hitting 2200 lumens! :D
Would be nice to see a light with it on copper and driven fully.
I realize manufacturers have to be conservative, but seems like there is a lot of unused headroom left, and heat sinking aside, little reason not to push harder.
Mine is on a .200" wide copper strip with the wires soldered direct to the underside of the LED, but still using the unmodified driver. Heat will not be an issue in this light - it does not have a pill, the emitter base is one piece with the middle section where the mode button is.
Actually handling the thing is weird. It has all the same proportions of a single 18650 light just scaled up by 3x. Or maybe that the light is normal size, but you've been shrunk down to 2 feet tall. :)
Well, i am waiting for a 4A version. So i’ll pass.
And oh yes, 6-9 months down the road, Ultrafire/Trustfire will be releasing the first triple MT-G2. Probably something like your showerhead 9 or 12 x XM-Ls maybe a little bigger head at 90mm diameter with a long body taking 4x26650s, but with quite a fair bit better throw in the same format.
