FLEX Asgard @ Fasttech
You pretty much nailed it…I will wait until they work out the kinks and the fervor dies down a bit.
That’s the thing with ‘technology’. Of course you can wait. In the future everything is going to be better (than now) definitely. But what’s important is you get to ‘enjoy’ it now, and by ‘enjoying’ it now, you fuel the next wave of improvements, because when there’s sales, then there’s incentive for Research and Development.
Let’s say iPad just launched… decided wait for the next one cause it’s not stable… okay iPad 2 comes out… hmm still not perfect… ok let’s wait some more… iPad 3… iPad 4… iPad 5 so wait forever and never got it. (Just using iPad as example, you get the point of the ‘endless wait’ cycle)
Sure, after a few months probably something better’s gonna come out, so that’s where the dilemma comes in. To buy now or to buy in future.
I do strongly suspect that you’ll play with the bluetooth settings till you find your ideal set up, then just use it as a torch, that said, I’ve voted with my wallet as this is to me, the most interesting development in torch tech since high output led’s, yes the zy-t08 is much cheaper, I have one, driven harder than this flex is, its a very very good pocketable thrower (jacket/cargo pocket), I just see this new driver making a very good light a great light and dont want to see the idea fade into obscurity due to lack of support.
I also suspect one of the reasons for using the zy-t08 is the huge aircraft sized empty driver cavity, as I doubt this driver and its associated modules is miniaturised yet, I’m very excited to take a peek under the hood.
And I thought that having modes at all in a flashlight was already a certain sign of civilization soon ending. So now those modes are bluetooth controlled...
from the sound of it, even on off is bluetooth controllable, I’m quite interested to see the app and what you can change about, its not available yet though, I’ve looked :frowning:
I wonder how many tubes of Loctite they will use to keep the fancy driver gubbins hidden away...
that’ll be difficult, you have to unscrew the head to change the cells, I’m interested in a blank contact board though, because that’s surely what they’ve used for this.
No one get it yet??? I want a review… J)
To answer a few questions, the welcome screen shows current voltage and core temperature (in C/F). It also allows you set thermal throttle level.
If you have used and like the FastTech support app, you should like the Asgard app as it’s designed with the same design language.
We will release it to the play store within a few days, before deliveries.
Hi,
That was why I was asking/suggesting about alpha/beta. I have the FT app on my Samsung Galaxy player, but it FCs intermittently. I think I reported via a ticket, but was suggested to just auto-report via the app itself.
Wow, thanks to Fasttech I'm thinking I should get an android...
Just wondering whether there is any fail-safe restore mechanisms in the case of corrupted memory or an error?
It would be horrible to get locked out from the light. :stuck_out_tongue:
remember when you asked me why android is better than ios? this :stuck_out_tongue:
dont you have an android based mini pc?
True. :P Sadly the MK-802 doesn't support bluetooth (no hardware and doesn't support a bluetooth adapter). I still think Fasttech should release an iphone version (preferably one for jailbroken iphones with a quick access toggle).
Man FastTech keeps kicking tail. I'm curious about the development process and who was all involved. I don't need to drop another $60 on any light, but this looks quite impressive. Cool to see that it separately turns on 7135s as well.
No offense but adding a BT interface isn’t really that difficult in the large gist of things. It would require redesigning drivers from the traditional norm but it could easily be done by the right people. People have been putting BT programming units on things longer than you might have thought of ;).
Making the App’s to control it and the code to interface with it may very well be able to be controlled by the person/corp who made it, however others could just as well make their own.
It looks cool, however I would still like the full metal + AR coating. Is there a way to have it so that it’s programmable, but not really useable outside of a few inches? The choice of host (Body thickness/Mounting, rings, etc) might make a difference too. Or an external antenna could be routed, or wrapped around in the body.
Unfortunately, Apple requires MFI and thus Apple tax to access Bluetooth data functionalities on iOS. We might be able to use it on Jailbroken phones but there may be potential legal hassles.
Looking at our internal work logs it seem that the problem was addressed a few days ago but not published on the Play Store. It’s published now so go ahead and update the app to see if it’s gone.
The app is simple and to the point. If there are quirks we’ll definitely work them out as soon as we can. I do understand your eagerness to see it but I’m not sure if there will be an alpha/beta since the actual release is only a few days away.
I only have a Mac. Can you tell what modes the light comes programmed with out of the box?
The default is Mid > Low > High. If really want to you can run the Windows app via your favourite Mac OS virtual machine.
At first, I LOL when you said “antenna”, but that might be a great idea! What they could do is make a lanyard with the antenna in the lanyard? That way it’d be unobtrusive, but still provide the signal reception improvement? I’m not a radio engineer, but I wonder if that’d work?
