I THINK, if I converted it correctly, that it works out to around 882 lumen which is well within the potential output and isn’t too shabby. I’ve already put in my order with my gal to have this wrapped and waiting for me come Father’s day!
That is the one I ordered with my F15. I don’t believe there is one specific to that model available for it yet. Word is that that reflector is compatible though. i will know for sure in a couple of weeks when I get mine.
Ive had mine for two weeks now and ive been happy with it. i guess one of the first things to do is to maybe get the LED epoxied to the pill because it just floats on it right now with thermal grease. i really dont think its hurting anything but the led can move off center. seems to dissipate heat well with that chunk of aluminum for cooling.
Hey Budgeteer, how long did it take to get yours from the time it ordered/shipped to when you got it? I am waiting on the one I ordered as well as an L2m I am itching to get my hands on.
Actually, i made myself one. Got a Lumapower clone host without markings from a friend. used a LCK-LED XM-L on sale at 6usd each and bought a 5 pack of kd 2,8A drivers. Already had the emitter insulator discs and thermal plaster. It was just a matter of well centering the emitter and doing a good job at soldering the driver. Later on fine tuned the reflector with some duct tape to have it sit where i want. It paid off. Very good centering of the xml gave me 38K lux at 1m which is quite good for a XM-L i think. Also it is the only XM-L based flashlight i have that has considerably less spill than expected. The reflector does it's jobe better than anticipated. I used the stock kd wires that came with the drivers. a bit on the short side yes but i managed to use them just fine. The KD 2.8A driver is a son of a "onion" to solder! I have to get a new solderin iron tip which is more pointy than the one i currently have.
Total cost?
Body free (worth max 10usd)
6,15usd emitter
4usd driver
0,2usd disc, solder and goop approx.
total:
less than 11usd without body.
Perfectly doable for 20usd if you can find the body for 9usd or less.
You may want to buy a MRV for 14usd at manafont... (SMO reflector incuded) but beware you have to shop for a 14 or 12mm XM-L star... My version accepted 16mm stars.
I used this torch for my XTAR battery roundup. Used a fan on the body and the flashlight stayed very cool to touch. Wihtout a fan however scorching hot in 10min. I can go for a 70min one shot if i keep it in hand easily without being annoyed from heat. Candle on high is however very unadvised. I forgot it on for 21min on desk and i was amazed how hot it was. I was able to handle it for a few seconds but not much more. I could if life depended on it... but i preferred to not stress myself over nothing.
